Bike will not start or stay running on a full charge battery/bought brand new battery, still same promblem,jump bike off,will crank ,ride bike for 30 min. park bike, leave bike running,lights start's to...
sounds like the problem is your battery is not charging when you are riding. The most common cause is a faulty regulator / rectifier. Contact a motorcycle wreckers for these parts, or your yamaha dealer.
Easy way to test is, when your bike is running, and the lights start to dim, before the bike shuts down, using a volt meter, test the voltage at the battery terminals, should be about 14V. If faulty rectifier,no charge going in to your battery, then the reading will be low, about only a few volts. If you dont have a volt meter, then any mechanic shop can do this test for you. best to have this done before buying any parts.
the battery is charged with the charger that came with the unit.per the owners manuel there is a built-in lithium battery.is it possible that;this is bad?
How do you charge your new battery?
When you mention the internal battery does it work?
