Marantz SR-5200 Receiver Logo
Question about Marantz SR-5200 Receiver
Marantz SR-5200, OSD problem
My Marantz SR-5200 receiver remote control doesn't now functioning well, especially the OSD buttom (or function). Is that anyway that i can manually go to OSD function (instead of using the remote control) to do the settings?
Can i get the OSD function, if i buy the Harmony 525 Advanced Universal Remote to replace Marantz SR-5200 remote control.
Posted by jascheow on
5 Related Answers
Anonymous
  • 682 Answers
SOURCE: Total loss of sound...what to do?
please repeat your setting first- and then disconnect all speaker out.
connect your speaker one by one until you find the bad one and change it-you can also apply contact cleaner spray over volume control and move it many times-please do not forget yo unplug headphone jack first.
Posted on Jul 06, 2008
Anonymous
  • 6 Answers
SOURCE: Marantz sr-7200 no OSD
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Posted on Aug 01, 2008
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
Anonymous
  • 247 Answers
SOURCE: need a user manual
here is a link for youe manual:
http://www.manualnguide.com/dl/5582/
please dont forget to rate this solution
thanks
tom
Posted on Dec 21, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: no surround modes produce any sound . only have
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Posted on Jun 03, 2010
My marantz sr 5200 has stuck in "Mute on" situation
Your mute switch has been broken some how,End will have to be replaced.
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
OSD control from receiver
I had the same problem on my 7200 until I realized that the display comes up on the television screen. I carefully followed the set up required from the manual. I got the Manual online at Marantz.com. I have a cable hook up so I connected the video cable out from the box to the Video in source on the 7200 and monitor out to my Television. I then pressed the Amp button to get the remote to Amp mode. I then pressed the OK button that is in the center of the four direction buttons and the menu displayed itself on the screen . I hope this helps. ercble
SR-5200 owners manual
http://www.retrevo.com/s/Marantz-SR5200-Receivers-review-manual/id/511dj791/t/1-2/
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
