Question about Samsung 32 in. LCD Monitor TV
How hard it is to replace by yourself main board Samsung LN-T4065
How hard it is to replace by yourself main board or lcd control board for samsung
ln-t4065f lcd tv ?
I have problem with my tv , 14 months old ,
it worked fine and by next powering , picture will come for 1 second , and then get lost
black screen , sound works , it changes channels , etc....
please help
Posted by macjasmin on
  • macjasmin Mar 30, 2009
    Thank you all for great answers , you are at help a lot , and I thank you .
    So my TV , have power , will show picture for second , and then turn dark. Sound works , tuner works , it will change channels ,
    Yes , even in dark screen , you can in a back that some images
    are moving , so I assume that TCON lcd controler board is OK
    Power Board is OK
    Only part to replace then is MAIN BOARD ??
    There is a add for LN-T4065F on EBAY AUCTION .......
    What do you think if I purchase that main board and replace myself?
    Is there any chance that I would solve the problem ??
  • Anonymous Mar 16, 2014
    power and main boards replaced about 2 years ago. TV is fine for about 10-20 min, then picture goes dark, with slight screen glow. Sound remains fine. If the tv sits powered down for a while, it will restart, but same problem occurs.
marionbagget
  • 718 Answers
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • marionbagget Mar 30, 2009
    Why would you replace the main board if you are receiving a picture and sound ? The problem would appear to be in displaying the image which is where the Inverter board and CCFT come in.
Wil Genet
    Problem Solver:
  • 14 Answers
Not hard at all. Just be sure that you remember where the screws go back into, and make sure that you are ground strapped to prevent any static discharge into the pcb's that you will be moving/replacing. I've worked on many lcd's and plasma's. Take it nice and slow and it will be ok.
Samsung LCD TV will not turn on or off. Red light
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Jan 25, 2010 | Samsung LN-T4065F Television
When you turn on the TV it takes about 20 to fully turn on. sometimes we get pink lines on the screen.
CHECK POWER SUPPLY BOARD ...OR REPLACED
POWER BOARD NO:
Samsung BN44-00167A BOARD, POWER (VERISONS SX07,SX05,SS03,SQ01)
Samsung BN44-00165A BOARD, POWER (VERSIONS SX08,SX06,SS04,SQ02)
Dec 31, 2009 | Samsung LN-T4065F Television
My Samsung LN-T4065F picture has red ghost like images. originally, the images would go away after a time but now appear to be permanent. the tv is approx. 18 months old and does not have that many hours...
I'd start by checking the cables going into and out of the tcon board, if that doesn't fix it chances are its a bad board, since it would take a few mins to basically warm up to work before it started doing this all the time one other thing you can try if its not cables is to bake the board..Chances of that fixing it are kind of slim but I have had it work a few times with timing boards I couldn't find. You can youtube this and find some vids on how to do it.
Nov 24, 2017 | Samsung LN-T4065F Television
Samsung LN-T4065F
clicking sound coming from television
Jun 18, 2009 | Samsung HCN4226W 42" Rear Projection...
Won't come on, only clicks
Dear Gary,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, BIG IRISH.
May 31, 2009 | Samsung LN-T4065F Television
Samsung 40 inch lcd tv
the issue is with capacitors on the power supply board ,open your TV and look for caps with damage on the top,the caps are 110 volt change them to 120v
and your issue will be gone.
I have done this with four of this kinda of TV and all are working like a charm
Nov 10, 2008 | Samsung LN-T4065F Television
Sound but, no picture
it could be the main, x or y, or buffer board
Jul 23, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-T4065F Dotted lines across screen
tell the idiots where u bought this tv from and demaand a more expensive and better tv on their bill
Mar 02, 2008 | Yamaha DV-S5950 DVD Player
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Open Questions:
See all Samsung 32 in. LCD Monitor TV Questions
Samsung 32 in. LCD Monitor TV Logo
907 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
