I have had builders install two new toilets. Neither has either an overflow or facility for an overflow.
Is the modern cistern designed to avoid need for overflow, or should I replace?
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
