Question about ATI RADEON 9800 PRO, (256 MB) AGP Graphic Card
Heatsink/fan assembly came loose from my Radeon 9800 PRO card.
Where can I send it to for repair? Or how can I repair it myself? I think it will continue to work if I can get the cooling system back up and running.
  • 170 Answers
Here is a site that shows the replacement of a heatsink fan on Graphics processing Unit...and Another place to find heatsink fans.....I hope this helps...Good luck...and thanks for rating my effort...the Fang.
http://www.xlr8yourmac.com/Graphics/Verax_G03_for_9800/verax_G03_9800_pro_install2.htm (this is all one link)
This is a nice site to let you cool your card down further than factory specs by replacing heatsink with an upgrade fan.
all one link as well
http://www.frozencpu.com/cat/l2/g40/c21/list/p1/Air_Cooling-VGA_HeatsinksCoolers.html?gclid=CP_XuJO2yZkCFQ_yDAodlBsLug
And this is the actual site that will show you step by step...how to change your heatsink...this is a great site to be a member of ...membership sign up required but free.
http://techrepublic.com.com/2346-10877_11-39297.html
Posted on Mar 30, 2009
6ya staff
SOURCE:
9800 PRO
CompUsa and Amazon sell them
Apr 22, 2012 | ATI RADEON 9800 PRO, (128 MB) DDR RADEON¿...
How to covert to Mac edition (ATI Radeon 9800 Pro)
Even if you do this, I would not guarantee it will work. Before you destroy it and void the warranty, you could probably return it or sell it on eBay. It's still a decent card for a AGP variety.
Jan 02, 2012 | Gigabyte ATI RADEON 9800 Pro (128 MB) AGP...
Auto shutdown broblem of mircomax X600, please solve the problem
1) What does the graphics card use for cooling? Passive or Fan?
If it is passive, and has no fan mounted to it, it is cooled with just a Heatsink attached to the GPU, (Graphics Processing Unit), and uses case cooling to cool it.
A) Heatsink; http://en.wikipedia.org/wiki/Heat_sink
The heatsink style used for a graphics card, does not stand as tall as a Heatsink used for a Processor.
B) GPU; http://en.wikipedia.org/wiki/GPU
If the Heatsink, and rest of the graphics card are covered in dust, etc, the GPU will overheat, and the graphics card will shut down.
2) Observe the age of the graphics card.
I just had an ATI Radeon X600X graphics card go out on me. It is at least 8 years old.
ATI made the GPU. The Radeon X600.
(It's AMD ATI now)
The Radeon X600 chipset is part of the Radeon R300 chipset series. (And also uses a PCI Express x16 connector),
http://en.wikipedia.org/wiki/Comparison_of_ATI_Graphics_Processing_Units#PCIe_.28X3xx.2C_X5xx.2C_X6xx.2C_X10xx
Actual exact code name of the GPU on your graphics card, is either the RV370, or RV380.
Looking at the chart, and using what graphics card you have, you can determine what chipset it is.
{ I'm also running a 22 inch wide screen monitor, and a 26 inch LCD HDTV for a monitor.
Dual monitors. Maybe that pushed the GPU over the edge }
For additional questions post in a Comment.
Regards,
joecoolvette
Nov 02, 2011 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Need replacement FAN for ATI Radeon HD2600Pro graphics card. Where are best sources?
Some ideas,
1) http://www.directron.com/ecvcribl.html
2) http://www.directron.com/eccuv2ab.html
3) http://www.directron.com/vnf100.html
Skipped past the ATI Radein HD2600 Pro, (More of an Nvidia fan), so I don't know how they have the fan/heatsink attached.
Don't know if they used Thermal Glue, or Thermal Paste for the heatsink. (Or a thermal pad)
It is Always best to replace the thermal compound. Cheap insurance.
A) Thermal Pad:
Remove the heatsink.
Carefully remove the pad the best you can, then use Q-tips dipped in Isopropyl Alcohol to soften the remnants. Follow with a plastic scraper, (Old credit card?), and more Q-tips dipped in alcohol.
Make SURE the top of the GPU is CLEAN. Then properly apply fresh thermal paste to the top of the GPU, and set the fan/heatsink assembly in place. Lock the fan/heatsink assembly down.
[ GPU
Graphics Processing Unit,
The GPU used in an ATI Radeon HD2600 Pro graphics card, is an ATI RV630,
http://en.wikipedia.org/wiki/Comparison_of_ATI_Graphics_Processing_Units#PCIe_.28HD_2xxx.2C_HD_3xxx.29
http://en.wikipedia.org/wiki/Radeon_R600
B) Thermal Glue:
Requires using a hairdryer set to low heat, and constantly moving the hairdryer's nozzle around slowly.
Once the glue softens gently twist the heatsink loose.
(Wear gloves)
C) Thermal Paste:
Use a clean plastic scraper, and plenty of Q-tips dipped in alcohol on the GPU.
(Isopropyl Alcohol. Commonly referred to as Rubbing Alcohol.
91 percent is best, 70 percent will do in a pinch. Advise against 50 percent.
50 percent alcohol, 50 percent water.
CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMAMABLE.
Use in a Well ventilated area with NO sparks or flames present.
Once you set the heatsink, or fan/heatsink assembly in place, and have it secured, look at a side view of the graphics card.
Room well lit, and a light background.
See if the heatsink is sitting flat. You do not want it sitting at a slight tilt.
As you can see, I am trying to steer you towards making sure the thermal compound, is in good shape. It is best to just replace it. Thermal paste is cheap stuff.
Regards,
joecoolvette
{To Add:
Heatsink:
Basic construction is a plate of metal with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, (In this case a GPU)
The tall, thin fins absorb heat from the plate.
The fins then radiate the heat away.
With a fan used in conjunction with a Heatsink, the air flow from the fan helps carry heat away.
Thermal Compound:
{Thermal Paste, Thermal Glue}
The top of a Processor, and the top of a GPU are not perfectly smooth.
A magnified view would detail, 'Hills, Valleys, and Pitholes'
Same with the bottom of a Heatsink. (The plate)
When the Heatsink is set on top of the Processor, or GPU, there are air pockets created from the imperfections of the two surfaces.
Air is trapped in-between the two surfaces.
{Heatsink on top of Processor, or Heatsink on top of GPU}
Air is an Insulator. Not a Conductor.
Thermal paste fills the voids, (Imperfections), and is an Excellent conductor of heat.
Thermal paste, (or a Thermal Pad), can dry up over time.
The thermal conductive properties are gone, or negligible ]
Aug 02, 2011 | Computers & Internet
Where can I buy a replacement fan for an ATI 9800 Pro Mac GPU ? The fan on mine has seized up and the card is causing the CPU to fail to boot on restart presumably because the GPU is overheating. I get a...
Most likely you can not replace just the fan on this card. If it is possible your best source for getting an actual replacement is going to be the ATI website. Search for repair or replacement parts on that site.
Oct 17, 2009 | ATI RADEON 9800 PRO Mac Edition (128 MB)...
5 beeps and no display
5 beeps is processor(cpu) failure
are they long? short?
Try another processor on the computer and see if it works.
do you get the same beeps if you place the old card back in?
Whats the brand and model of the motherboard?
its reads between the cpu and memory and also between the expansion slots, and possibly on top of a heatsink
let me know
Thanks,
Ekse
Feb 17, 2009 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Ati radeon 9800 error message on bootup
the error means that you do not have a power cod connected on the card or the power supplied by the PS is not enough for the card to run.
Remove power from the parts in the PC that you are not using anymore and try to reinstall the card.
worst case is getting another power supply about 600 watts
Nov 08, 2008 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Swap 9800 Pro for 9700 Pro
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
http://ati.amd.com/support/driver.html
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
Oct 30, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Fan not working
It can. but it can be a number of problems as well. How long has it been since you cleaned out your computer? How long have you had the computer? Do you play a lot of games where the video card would be used a lot? Here's some things that you can do to maybe fix your problem. 1. goto: start -> run type in "msconfig" goto the last tab "startup" and disable all. restart computer 2. goto: start -> all programs -> accessories -> system tools Now...in this menu you'll want to do 2 things "clean disk" and "defrag" (both of which will most likely take hours of doing) 3. Get a heatsink to put on the video card where the fan was and that should do the same thing as long as you have a good fan in the PC. On another note, you could probably get another fan to put in your system (especially if you like to play a lot of games on your PC)
Mar 28, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
ATI RADEON 9800 PRO, (256 MB) AGP Graphic Card Logo
Top ATI Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
