Question about Apple iPod MA446LL/A MP3 Player
Dead battery? My iPod mini is not holding its battery charge. I charge it for several hours, and it tells me it is fully charged but when I use it it immediatley shows low batt.
Posted by boymurph on
Steve Brown
    President:
  • Apple Master
  • 688 Answers
Lithium-Polymer and Lithium-ion batteries don;t have them memory problems the the prior post is mentioning.
your ipod battery either takes a charge or it doesn't.
I have run accross numerous ipod that when the mainboard has a problem they will show Low-Battery signal.
If you have an a/c charger, plug it in to your ipod and see if it comes alive. If so it's the battery, replace it. If you get a low battery screen when you ipod is plugged into the a/c charger you may have a problem with you ipod mainboard.
But the battery in an ipod has no charge cycle like the old batteries did.
If this post helps you please leave a vote at fixya
Posted on May 24, 2009
Mel Neilsen
  • 342 Answers
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
For free video on iPod repair go to: http://fixyouripod.weebly.com
For "cheap" iPod parts go to: www.ifixit.com
Posted on May 19, 2009
Anonymous
  • 40 Answers
Battery is bad. If you use a dock most of the time, it is overcharging or never gets the chance to relearn its capacity. If it just shows low battery but will still work, just run it with a low battery until it shuts off. Then recharge it completely. Do this three times. If no improvement, you need to replace the battery.
Posted on Apr 25, 2009
Can my car hold a charge to get it to a dealership if it is dead due to a bad alternator?
if you have a fully charge the battery and you have had the battery load tested to ensure that it is a good battery then a fully charged battery will run an engine for several hours providing that there are no other power draws on the system. That means -no big radio ( amplifiers ,cds, blue tooth)draws -no lights -transmitters --cigarette lighters ---power window usage Especially no repeated starting of the engine
Aug 20, 2014 | Cars & Trucks
There is no sound or display on the screen when it is power on
The Apple iPod uses a rechargeable, lithium-based battery that can go between 10 and 36 hours between charges, depending on the model. You can charge your iPod using either an electrical outlet or your computer's USB port, but if you find that your iPod no longer takes or maintains a charge despite having the right connections, you should try some basic troubleshooting methods to restore the device's battery life.
Connect your iPod to a different USB port or wall outlet. If you use a USB port to charge your iPod, you may simply have a low-powered port, according to Apple. You can often resolve this by switching the cable to a different port, or using a wall charger (sold separately) to recharge instead. Charge your iPod for several hours. If you find your iPod completely unresponsive even as it charges, leave it plugged in for three or four hours and check again. If your battery life has been depleted completely, the iPod will need time before it can begin functioning again. Restart your iPod. A frozen or dysfunctional iPod may fail to charge, but a quick reset can fix basic functionality glitches. To reset a touch-wheel iPod, hold down the "Select" and "Menu" buttons until the gray Apple emblem appears on the screen. For iPod Touch, hold down the "Sleep" and "Home" buttons (the only two buttons on the device). Connect your iPod to your PC using the provided USB cable, open the iTunes software and click the "iPod" tab in the left column. Then click the "Update" button to search for and install the latest iPod software. Apple recommends keeping your software up-to-date to ensure that your battery life remains fully optimized. Purchase a new battery from Apple. If your battery fails to charge despite all your troubleshooting efforts, it may simply be too old and depleted to continue functioning. By taking advantage of Apple's iPod Out-of-Warranty Battery Replacement Program (see Link Below), you can send in your iPod and receive a replacement battery or replacement http://www.apple.com/support/ipod/service/battery/ iPod for a modest fee.
Feb 11, 2013 | Apple iPod Audio Players & Recorders
How long to charge the ipod to your computer?
Fully charging the battery takes about 4 hours. You can also fast-charge the battery to 80 percent capacity in 1 hour (2 hours for iPod (Click Wheel)). Charging the battery may take longer if you're using iPod as it charges.
Mar 09, 2011 | Audio Players & Recorders
Ipod won't power on. Computer won't recognize it.
Step 1: Check to see if your iPod can still be charged by charging it using a wall charger and wait for it to fully recharge.
Step 2: If it does charge fully, try using your iPod normally and see how long it lasts. If it lasts for only 2 hours, your iPod battery may be dying. If it doesn't charge at all your iPod may be dead.
Step 3: If either of the cases are true then you have two options:
  1. If your iPod is less than a year old, you can bring in your iPod to the Apple Store and have it replaced for free on the spot as part of its 1 year warranty.
  2. If it is older than 1 year, you can go to the Apple Store and have them replace the battery for a fee
  3. If you are looking for a new iPod anyway, go to the Apple Store with your old iPod, and tell them you are looking for a new iPod. They will give you a 10% discount when you hand your old one in.
Feb 13, 2011 | Apple iPod touch
My Ipod only works when connected to computer, once i disconnect immediately turns off. whats could be the problem?
When the IPod is connected to the computer, it also charges the battery.
Leave the IPod connected to the computer for several hours so it can charge the IPod's battery.
When you disconnect the IPod after several hours and it still turns off, then the IPod's battery is dead and needs to be replaced.
Sep 19, 2010 | Apple iPod nano 3rd Generation
My ipod wont hold a charge. It keeps going out
How are you charging it?, if your charging it on the computer it slowly decreases the batery life everytime you charge it ( as in it last for 5 hours to 4 and a half) so i suggest you start using a wall charger in future :)
Dec 12, 2009 | Apple iPod mini M9160LL/A MP3 Player
Help help big prb
your battery is dead. fit a new battery, or take it into a shop and get them to fit a new battery. I had the same problem with mine (ipod video) and its been perfect ever since.
Aug 19, 2009 | Apple iPod nano
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
IPod mini battery dies when nearly fully charged, often while skipping songs.
iPod batteries are cheap on ebay...like $5...and come with installation instructions. Try installing a new battery and see what happens...?
Feb 11, 2008 | Apple iPod mini 2nd generation MP3 Player
Won't start
how old is the battery? if it's more than 2 or 3 years old, it may not hold a charge. swap a known good battery and see if it works.
Dec 10, 2007 | Panasonic AG-DVC30 Mini DV Digital...
Apple iPod MA446LL/A MP3 Player Logo
125 people viewed this question
Top Apple Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
