Question about Cameras
Kodak si xe
My camera wont even come on and ive only had it for a couple of months earlier today i turned it on and the green light came on then the light turned red immediately and the camera went off now it wont come on at all and i dont know if it could be the battery or what but i spent alot of money on this camera and ive only had it a couple of months
Posted by kntrigrlkuti on
5 Related Answers
Anonymous
SOURCE: my kodak c743 isnt working
Get the camera repaired. I bought a C743 camera with this problem and noticed it was draining the batteries dead while turned off. I measured the off current and found it to be extremely high (as much as 100ma). This is around the amount of current a flashlight draws when turned on.
Posted on Sep 03, 2007
Anonymous
  • 173 Answers
SOURCE: My Samsung S850 Wont Turn On
cameras beep when it has a problem. most likely the lens get stuck or lens gear failed or motor drive gear to lens, or allot of other problems like it doesnt reconize the optical sensor.
look online for the beep codes and problems.
ty
hope I helped
Posted on Feb 17, 2008
Anonymous
SOURCE: GREEN LIGHT TURNS TO RED & CAMERA WON'T WORK
send it back and purchase a different camera
Posted on Jun 29, 2008
Anonymous
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
Anonymous
  • 2761 Answers
SOURCE: Kodak Easy Share M763 Won't turn on!!
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
Kodak easyshare dx6490 charger indicator light is on but battery wont charge
Sounds to me that if you bought 2 chargers then you have a bad battery. what are the odds that you have 2 bad chargers ? Time to buy a new battery.
1helpful
I have a kodak easyshare cd82 blue camera it is 6 months old it was working fine until a couple of weeks again i got it out the case turned it on and the screen was white with green cracked like lines on...
All devices including digital cameras are protected by a 1 year warranty. The green cracked line indicates a hardware problem, and since the camera is on its 6th month, it is still covered by warranty. You should take it to a Kodak authorized service center (not to the store you purchased the camera) to avail the warranty.You just need to bring the purchase receipt.
Kodak Easyshare wont turn on with a full batery
Remove your battery and memory card for 15 min and put them again. (you can also try by putting new batteries. In some cases battery can be faulty.) Then restart your cam. If then also problem persist, Sorry you have to get it serviced. there is a mechanical problem.
Please rate the aswer
1helpful
2answers
Nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting). Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
1helpful
2answers
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
1helpful
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Kodak M1033
i think there should be some problem with your shutter.. so you can open up your camera and chck for your shutters....
4helpful
3answers
Green light goes to red
What type of new batteries did u put, same as original ?
2helpful
2answers
Stuck :(
My Kodak DX6440 did the same thing. After sending it to Kodak's third-party repair (as per Kodak), they called to say it was not fix-able. Kodak's response was "No parts available" and offered 10% off list price of a refurbished camera. ...Big sports ...Way to keep customer loyalty If you choose Kodak, the cameras are good but buy them knowing they are a disposable item. BK
Open Questions:
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
