Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
Start runs shutsdown
Says overcranck
Posted by shane_mullis on
Sheldon Dedek
  • 912 Answers
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Posted on Aug 25, 2009
I have a hitachi cs40 and whe I prime it 10 times it starts up and runs until the prime is gone the shutsdown.
rebuild the carby as the diaphragm is not functional and pumping the fuel up
Feb 05, 2017 | Cars & Trucks
Engine starts nicely for about 5min after that later engine shutsdown.
run the fault codes to see which sensor fails when it get hot
could be a faulty ECM
could be a faulty ignition control module
could be a coil/s
it appears that when an electronic component gets hot the unit fails
Sep 03, 2015 | Cars & Trucks
My laptop shutsdown when i start to download online, i just bought a new printer but i dont have a cd room to install it
Are you downloading the file(s) or trying to run the install from online site? If you are trying to run from online try downloading file(s) to save on your pc and run from the folder you choose to save to.
Jan 09, 2013 | Acer Aspire Computers & Internet
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
TV Starts but then shutsdown
I'm having the same problem, but I have a 13" with built in vcr. It acts like it's jammed with a video tape (it's really empty), and turns itself off.
Feb 16, 2008 | Zenith B25A24Z 25" TV
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
1,576 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
