Pentax Optio S4 Digital Camera Logo
Posted on Aug 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera says Card Locked
Not sure how I did it, but I did.... can't figure out how to unlock the card???? Please help!!!
RickyDicky
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 09, 2008
RickyDicky
Contributor
Level 1:
Answers
Questions
0
Helped
76
Points
WOW!!!! THANK YOU !!!!!!
Anonymous
Level 2:
Scholar:
  • Expert 72 Answers
  • Posted on Aug 28, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
72
Questions
Helped
104344
Points
141
Take a close look at the side of the SD card, there should be a little plastic switch. Click that the other way, and that will solve your problem.
2helpful
Memory card locked
And you looked if the card was locked?
The 64GB card is unlocked the 32 GB card is locked. So make sure the switch is up when you see your card like these two.
When you are sure your card is unlocked, just check if all contacts of the card and in the camera are still clean, shiny, and straight. (no bent in any contact)
9helpful
Card locked
Remove your card from the camera.
Unlock your card shown in the upper figure.
4helpful
2answers
Card locked please help
There are two reasons for card locked problem Canon PowerShot A400.
One is card locked while camera opening. The answer for this is explained in below figure.
34a2e3d.jpg The other one is dealing with card itself. The below picture shows that.
68ed342.jpg You may need the user manual for other problems.
This is User Manual of Canon PowerShot A400
If you find this helpful please vote.
1helpful
Picture is locked on card
Hi there
Make sure the write protect is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Hope this helps.
4helpful
2answers
How to get my memory card unlocked
Take your card out ... there is a white knobby thing on one of the sides of the card. Make sure it is flipped up (up is unlock, down is locked) ... should help you. This just happened to me - it took me awhile to figure it out! Good luck.
8helpful
2answers
Cannot unlock memory card for my Canon Powershot S5IS
OK take out the memory card and on the side of the card is a small switch...slide the switch to the unlock posistion and that should fix ya
!Please rate this response and help us keep this area free!
Thank You!
2helpful
6answers
Memory card blocked!!
I have the same exact problem with my camera and NOTHING works. Bought a new card, didn't work. Checked and rechecked the card to make sure it isn't locked...didn't work. I have no solution for you but to tell you you are not alone with this problem and it isn't your card or the little slider on your card. It is within the camera.
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
4helpful
Memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
2helpful
Unlock card
- Turn off camera
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
