We have imovies08 on our MAC OS X Version 10.5.6 and it is supposed to automatically open an import window when my camcorder JVC GR DVF 21 is connected to the MAC with a firewire. It doesn't. Does anyone have any solutions so that I can import video from the GR DVF21 to the MAC? Someone mentioned elsewhere recDV application, but it didn't work for us. Am I missing something?
SOURCE: Problem connecting JVC GR D370U
I have JVC GR-D270 cam how I can copy my video from tap to my Laptop
SOURCE: JVC GR-D73 DV CAMCORDER
Link download:
http://uk.jvc-service.net/public/document.cfm?prog=ProdSoft.cfm&Model=GR-D73
SOURCE: JVC GR-DVF 21
Nope. The common cause of this is either dirty heads or an alignment. Try a head cleaner first or just run a blank tape from start to finish is scan mode (play then FF as a scan). That should resolve the problem. If not, then we'll go to the next step.
Dan
SOURCE: can't transfer videos from JVC Everio camcorder onto my MAC
Share: How to import .tod files from JVC Everio HDD Camcorder to iMovie?
Requirements: iMovie (Part of the iLife 08 package)
Step 1: Connect the Everio to the Mac (Via USB)
Make sure you are powering the Everio from the mains before connecting your JVC Everio Camcorder.
Step 2: Playback on PC
Select “Playback on PC” on the Everio, once connected you will see the Everio HDD symbol appear on the desktop. The video files on the Everio are stored in the SD Folder/PRG***/MOV***.MOD.
Step 3: Open iMovie
Once you open iMovie, you will see that it recognizes the Everio straight away and will attempt to import your video.
You are now ready to use iMovie to edit your video files.
If need change .tod files to common video formats like mov, mp4, m4v, mpg, mpeg, dv, flv, avi, wmv, 3gp, mkv, mp3, aac, wma, m4a, etc. Mod Tod Video Converter for Mac is a good choice. The program can also convert mod tod to ipod, mod tod to iphone, tod to apple tv, tod to blackberry and more devices!
SOURCE: I have a gr-dvf21 camcord that I want to use on my
If you can buy the tuner card, and do the recording. The best tuner card is from WinFast TV 2000 XP. It has video in, capabilities and recording is easy. It not even expensive and even you can edit the video in a professional way. i have done on many occasions and found out to be very reliable. Regarding to the camcorder, you have, if possible get the software driver and load in your pc. Read the instructions carefully and try to use it.
