My volume icon keeps appearing and if run up the volume it keeps running it down to nothing . it will not stop. can not increase volume but volume icon keeps appearing randomly
you will need extra knowledge on iphone. you will need to open the iphone. extra technical knowledge and tools are necessary to open iphone. once opened, clean up the two button meant for volume.
Hold down the "Sleep/Wake" button at the top of the phone. After a few seconds a notice saying "Slide to power off" will appear.
Hold down the "Home" button. This is the square button on
the iPhone under the screen. After about ten seconds a yellow triangle
and a notice saying "Please Connect to iTunes" will appear.
Plug the iPhone into the computer on which are running
iTunes. You must have an iPhone or iPod USB cable, because the side that
is inserted into the iPhone is unique to Apple.
5
Open iTunes. If you do not have iTunes, you can download the latest version from the Apple website.
6
Click "OK" when iTunes shows you a message saying "iTunes has detected an iPhone in recovery mode."
7
Click "Restore" on the window that appears, and then let the
restoration process run and complete. This is the "Summary" tab for the
iPhone. You can go back to this window at any time to restore the
phone. The icon for it is located on the left-hand side of iTunes.
Fixya only runs in your web browser so there should be nothing to get off of your computer. If you have the iphone app on your phone, just tap and hold the icon until a small black x appears.
Yes, its possible to hard reset your tablet. Turn off the device, hold the power and Volume up buttons together. Once the device turns on release the power button and continue to hold the volume up button. A Sceen with the android service icon will appear. Press the Volume up button once more then you will see a couple of selections. Press the volume down button and select (wipe data/ factory reset) option. be sure to press the power button to select the option. scroll down using the volume keys to (YES- Delete all user data) then press the power button again. Your device will begin to wipe its self. Once the selections appear again select (reboot system now) your device will restart and youll be back to when you first purchased.
Francisco Torres
Wefix Wireless Technician Wefix Wireless
when you hold the Iphone in your hand with the round button with the square inside it on the bottom of the phone. turn the right side of the phone down to the floor while you do this look for 3 buttons on the side of the phone the TOP button must be pushed upwards at all times this flip switch is your MUTE switch pushed down it is in must mode switched up is sound mode. Below this is 2 buttons the button just under the top flip switch is volume up the other one is volume down there ya go. Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance.
Volume Control - The volume icon does not appear in the notification area (system tray)
Go to Start/Control Panel/Sounds and Audio Devices.
On the Volume Tab under Device Volume, put a check in the box that reads: Place volume icon in the taskbar.(Classic View)
If that has been tried:
Place your XP CD in then go to Start/Run and type in: EXPAND -R X:\I386\powrprof.dl_ C:\Windows\System32 (X- is your CD location)
Once done: Go to Start/Run and type in: regsvr32 stobject.dll or How to fix system tray icons missing in vista and xp
For those who like to do it manually, open the command prompt and type the following two commands one by one:
From the command prompt, type "taskkill /f /im explorer.exe"
"explorer.exe"
just hold down the two buttons (one on the top of the iphone, and the control button on the front)
Hold them down til the phone powers down. wait a minute or two, then restart the iphone.
-ep
