Question about GE WSXH208A Front Load Washer
GE Adora Frontload Washer shredding clothes
Machine less than 1 yr old. Problems started as soon as I accepted delivery. Machine is very loud during cycle, and barrell bangs during wash. Cycles take much longer than they should, and loads are soaking when at end of cycle. Repairman came to check machine, said nothing is wrong, there is nothing he could do. Machine adjusts itself to balance causing length of cycle to be longer. (Where is the efficiency in this??) Said I was not operating it properly (I have been doing laundry for 25 yrs & have not had these issues, nor do I have these issues with my other GE frontloader-different modle-at our vacation home) Was told need to pack the machine with clothes, wash large loads. Now my clothing is being shredded!!! I am furious, over $400.00 in clothing has been ruined!! Spoke to GE svce center and was told they have received these reports previously. Was transferred to supervisor & was told would need to send repairman out again since it has been 1 1/2 months sine last time they were out. If repairman says nothing worng with machine there is nothing they can do. Any suggestions??? has anyoe else had these problems??
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Posted on Mar 31, 2009
Washer turns off during wash cycle for no reason
Motor probably overheating. How old is it?
Dec 01, 2013 | Washing Machines
Noise during spin cycle
what noise is it making, it may just be off balanced
Jan 17, 2012 | GE WSXH208A Front Load Washer
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Frontload Washer Adora series duet pair
you may or may not hear clicking as it tries to start.
See this link for troubleshooting it. and to open door.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Feb 02, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE WSXH208A Front Load Washer Logo
535 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
