Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Hi limit device trips prematurely (should only trip when oil temp reaches 450F). Check if the hi limit sensing bulb (located inside the fryer tank, between fire tubes) is not touching the fire tube because if it does, it will sense the heat from burner flame which is much higher than oil temp.
try to change the thermal battery the device that the pilot heats.. other wise there is a screw at the botton of the automatic valve.. try to increase the pilot so it can heat more the thermal battery! u dont have enough voltage to activate the solenoid valve so thats why ur pilot goes off
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
The thermostat is acting up,The t-stat controls the heat,did you replace the pilot valve or gas valve?If there is 1 valve make sure the wires are in the correct terminals.
