Question about Bunn BCW Coffee Pot and Decanter Warmer
Bacon grease in my bunn coffee pot
Bacon grease dripped into the top of my bunn coffee pot. how do i get this cleaned out of the inside of my coffee maker? I've used white vinegar but nothing?
Posted by sunnybrooke on
atbsmmom
  • 189 Answers
Did you let the vinegar mix with the hot water in the tank for 2 hours? If this didn't fix the problem, please call 800-352-2866 with the model and date code and we will be happy to assist you with this problem.
Posted on Jul 01, 2010
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
Cleaning
The metal proble is use to clean out the water tubing. Remove your sprayhead and insert the metal rod up in the hole leaving out about 1-2 inches. Then simply twist and turn the rod about 5-6 times. This will remove any lime deposits. Then flush out with 2-3 decanters of water. You can obtain a new manual by calling customer service or going to the website-www.bunn.com going to @home, then products-click on your brewer-and then select use and care manual and you can print it out or view it online.
May 19, 2010 | Bunn 10 Cup Home Coffee Brewer
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
This is commercial and the water drips instead of flowing,took 20-30 min to make coffee, how can i clean?
Have you tried to brew without coffee to see how long it takes? If yes then use a pair of channel locke to remove sprayhead and then use the deliming sprding that came with your bunn and clean the brew line then try again, if you still get the ame result, the brewer needs to be descaled.
May 06, 2009 | Mr. Coffee Coffee Makers & Espresso...
Cleaning advice of this maker seems necessary
Start cleaning process with vinegar, several times.
Mar 27, 2009 | Bunn VPR Coffee Maker
Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Jan 11, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffeemaker
The Bunn coffee machine has an internal tank used for holding approx three potfulls of water at just below brewing temperature. When you add water for a potful, the thermostat senses cold water and starts the brew heater. The water level inside the tank comes up and goes through the sprayhead. This "surge" of water, that you call drips is normal. The hot water stratifies to the top of the tank, just like an electric water tank in a house. The internal pot heater kicks in and boils the water already in the tank, raising the water level in the siphon pipe to the sprayhead until the reservoir under the add water opening is empty.
Sep 15, 2007 | Bunn NHB Coffee Maker
Bunn BCW Coffee Pot and Decanter Warmer Logo
190 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
