Question about Mr. Coffee Classic 12-Cup Coffeemaker - Cocoa (MRX35)
"clean" light will not go out
Used the clean function. now can not get the light to go out. click it once and it blinks. click it again and light stays on. have even unplugged coffee pot and it comes back on when I plugged it back in. do not have owner's manual
Posted by melissagm on
Anonymous
    Scholar:
  • 40 Answers
In my experience with this coffeemaker, the Special Cleaning Cycle light doesn't illuminate until the machine is very clogged up. The risk of ignoring this indicator and waiting too long to clean it is that by the time it does get cleaned the calcium deposits will end up clogging the check valve, thereby shutting down at once. Regular cleaning will prevent significant amounts of calcification and thereby result in hotter, better tasting coffee and less risk that the loosened mineral deposits will end up clogging vital parts of the machine if and when you do clean it.
If you notice, the inside of the lid to the water tank states that the unit should be cleaned every 30 days. This is true whether you see the cleaning indicator light illuminated or not. To clean the coffeemaker, you must add 20 oz of undiluted white vinegar per the owner's manual, then press the "clean" button. If you do not recall the last time the coffeemaker was cleaned and wish to start off on the conservative side, you may wish to use a diluted solution of white vinegar (about 1/3 to 2/3 water).
The coffeemaker will brew part of the vinegar, then pause 30 minutes, then restart itself. Use clear water to rinse at least two times after the process completes. This will take about an hour in all. If you are in a hurry, you can just run vinegar through a regular "Brew Now" cycle; however, this will be somewhat less effective.
When adding fresh, cool water to rinse the vinegar out, make sure to allow a few minutes to cool down between rinses because the element is extremely hot. You may wish to use a vessel other than the carafe to fill the water tank while rinsing because it will take less time. Otherwise, the carafe may crack or shatter if you take it off the hot plate and fill it with cool water straight away.
Finally, I suggest you visit MRCOFFEE.com and put the model number in their web search box. The Classic Edition Coffeemaker came in three varieties: MRX33 (black), MRX35 (brown) and MRX36 (red). The instructions are otherwise identical in operation and features. There will be a link at the bottom of the description to the user manual. If the model number no longer appears on their site, use your favorite search engine and type "model + manual + PDF" or terms to that effect.
Posted on Mar 05, 2010
Anonymous
You've got to let it go through the entire clean function. The entire cycle takes 45-60 minutes.
Posted on Jun 14, 2009
Anonymous
    New Friend:
Oh yes yes yes, that solution works just fine. Fine I say. However I like drgfer's better the uh um 243 vs 270 at 100 yrds. I used a 50 cal. at 300 yrds, however first I filled the carfe with methelethelkeytone and lit a ring of fire around the entire pot....... WAMIE! whew should post it on you tube.......Oh OH I will. Go right now to WHAMIE COFFEE POT!!!!!! oh oh it's nice very nice!!!!!!
Posted on Jan 16, 2010
How do i change the numerical code?
How to change or program code on your Craftsman Liftmaster keyless keypad made by Chamberlain.
1. Program using the "Learn" Button
2.
Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
  1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
  2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control. Both of these should now be held down at the same time.
  3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
  4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Change an Existing, Known PIN
If the existing PIN is known, it may be changed by one person without using a ladder.
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  2. Press the new 4-digit PIN you have chosen, then press ENTER.
The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN, then press ENTER. The door should move.
Your new Keyless Entry must be programmed to operate your garage door opener
May 24, 2011 | liftmaster 977lm 976lm Liftmaster...
I used the Self Clean function on the oven and now the oven will not pre-heat or heat at all. All that happens once the clean is complete is that the clean light blinks. I have cycled the self clean...
unfortunately the reset button is usually inside the controls compartment, the upper back piece has to be opened and push the red reset button inside.Hpefully this helps and dont forget to unplug first for a couple minutes to attempt erasing fault
Jan 20, 2011 | Ovens
I have a Series 118 Pierre Cardin Quartz alarm with 3 buttons: Light, Set and Mode; I can't figure how to set/change the time
mcdevito75 here, The mode button is the button you need to depress to set the mode of the watch. Depress the mode button once, see if anything on the face is blinking, if it is use the set button to adjust the time/date You may have to depress the mode button twice or depress and hold down the mode button a couple of seconds to get the face/display of your watch to blink, after you make 1 adjustment to move to the next depress the mode button again until you get to the next adjustment, or the next function to set on your watch. After you"ve set all the functions depress the mode button again to stop the blinking a show a steady display.
Jun 12, 2010 | Watches
Canon ip1800 green light blinks once and orange light blinks three times
try to clean the circuit of the cartidge with dry tissue or cotton cloth with little alcohol if blinking again replace new one black or color catridge
Jan 27, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
May 30, 2009 | Kenmore Dishwashers
My MP 160 Canon cannot print alarm is blinking and copier set to zero and cannot function as printer, copier and scanner
This may be the ink pads try this for now but you will need to clean it out some time.
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    Mar 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Green clean light keeps blinking
    HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
    Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
    Blinking orange light
    Ride me I can help you Contact me on Live expert ttech
    Jul 21, 2007 | LG RU-60SZ30 60" Rear Projection...
    Mr. Coffee Classic 12-Cup Coffeemaker - Cocoa (MRX35) Logo
    20,235 people viewed this question
    Top Mr. Coffee Coffee Makers & Espresso Machines Experts
    Mat Kramer
    Mat Kramer
    Level 1 Expert
    Kelley Hopper
    Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
