Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48 Logo
Question about Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48
Need to know what type of freon to use to recharge a one yaer old Beverage Air Sandwich table refrigeration unit. Is this the same process as recharging an automotive AC system?
Posted by rcalatrello on
  • 1 more comment
  • Anonymous May 23, 2009
    freon to use in cr28kf-pfv-230 s3qa-030ka 2.5 ton unit
  • Dennis Boxerman May 11, 2010
    You get me a model and serial number and I'll try my best to get you an answer.
    Need model and serial and I can probably get info for you. No you do not charge this like an auto system.
Anonymous
    New Friend:
  • 110 Answers
There is a data plate on unit somewhere most likely 134A.
Posted on May 09, 2010
Northeast Cooling LLC
  • 122 Answers
It will probably be R 134A gas. Tell me the Model # of compressor and I'll tell you the type of gas! It will be different from charging a car. Beverage air are usually critical charge. This means you have to weigh the exact amount of freon in that is listed on the nameplate of the unit. (next to the charge info will be the freon type) I can ball park it by pressures, I would not recommend you try that. ;)
Posted on Sep 23, 2009
Anonymous
  • 3 Answers
Most is R134a gas
Posted on Aug 04, 2009
  • Anonymous Aug 04, 2009
    TRY R134A GAS
Commercial Appliance Service, Inc.
    Scholar:
  • 81 Answers
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Posted on May 02, 2009
  • If the unit is only one year old you should use R134a. The refrigerant charge should be put in by weight only. If you go by pressure you will likely be wrong and have further problems. The proper method is to have unit in vacuum and weigh refrigerant in on high side in liquid form (turn bottle upside down). Using a scale weigh in the amount listed on the data plate. If the system has be opened you should also install a new drier. Hope this helps. By the way, Beverage air has a good warranty, if the unit is less than a year it should be covered.
Refrigerator side frost build-up.
Every one of the issues the techs gave you are possible solutions.
How do I recharge a 15 yr old Freezer Model #UL2494ECW8
U have to buy and install a shrader valve on the low side going to the compressor. Correct refrigerant charge is critical and you need to carefully measure and introduce the correct amount of freon, preferably with a refrigeration scale.
Jun 02, 2015 • Freezers
What are the minimum and maximum operating temps for a beverage air sur72-30m prep table cooler?
Most all manufacturers try to build units to hold between 34 to 38 degrees as this is the most commonly accepted range for coolers by all Health Departments.
Freezer not freezing acting like refrigerator
Either the thermostat went bad or the refrigeration system has a leak and you are low on freon....that will also cause poor cooling..
heatman101
How can i recharge the a/c on my beverageair ur30g because is not getting cold
Recharging a refrigeration unit takes a ton of experience and specialized tools and equipment...
Check out the things in these tips first and then call a professional if you need to have gas put in...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
It is blowing hot air!
http://www.beverage-air.com/Main.aspx?pid=74&tab=75
I went to this web site and found several manuals on your unit. check it out.
Hope this is what you are looking for.
Be sure that the condenser on the back of the unit is clean and that the unit is not pushed back up against anything that can block air flow around the condenser.
Start there. If you need more, let me know.
1helpful
Evap fan will not come on,jumped out the fan control fan comes on
Since this is a freezer, it should have a defrost terminator/ fan delay. This could have gone bad or you may have a refrigeration problem. Such as low on freon due to a leak. Need more info, I'll explain in detail. Let me know. Will Be more than happy to.
Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
2answers
Top Beverage-Air Freezers Experts
Marvin
Marvin
Gil Shultz
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
