My oven will flash F9 and turn off during cooking. It seems to no longer be venting out of the top of the stove. it almost seems like it can't vent so it over heats. Any ideas?
SOURCE: Problems with my LG electric range modle no.
Thsi sounds like there is an issue with the thermal system because when it heats up it works and when it is cool it has trouble. have you tried to contact LG and see if they can get you a replecement part?
SOURCE: F9 Display in Model MGR5770ADB Gas cooking range
f-9 means you either have a bad door latch hinse the light staying on, or the ERC which is the oven control has a stuck relay and youd have to replace the ERC to fix it.
SOURCE: How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
