Brinkmann Stainless Steel All-In-One Gas and Charcoal Smoker/Grill/Fryer 810-5100-0 Logo
Posted on Mar 29, 2009
Lost manual/instructions for rotisserie Brinkmann Pro Series 4435
I can't find the manual for my Brinkmann 4435 Pro Series; it has 4 burners and a side burner and a rotisserie. I want to use the rotisserie but have no instructions. Where is that information available ?
Thanking you in advance
Lorraine
B. McDonald
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on May 30, 2010
B. McDonald
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
5727
Points
16
I have found that Brinkmann's Manual page listing is woefully unacceptable as to the models it supports.
So, I think the best thing for you to do is to contact Brinkmann directly and they can help steer you to the proper source OR mail you a copy of the manual needed via snail mail.
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
652
Points
I have lost the owners manual and need to know how the trays are set up inthe smoker for a brinkmann grill 810-1750 sc
Here is a link to a pdf version of the owners manual: http://images.brinkmann.net/docs/pdf/810-1750-S.pdf
It will take a second to load, the assembly instructions for the trays in the smoker are on page 27, hope this helps!
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
1helpful
Brinkmann Pro Series 2545 Assembly - The side burner valve nozzle does not fit firnly into the burner venturi. The venturi (pipe) is about 1 inch too short!
When you attached the side burner assembly to the grill frame, did you pull it forward before tightening the 4 bolts that hold it in place? If not this could account for part of the problem. The other would be how you routed the gas line hose from the 'Y' connector, to the side burner connection. If routed differently than what the assembly instructions indicate, you would come up short on the length.
In any event, your model grill has been discontinued by Brinkmann, but the warranty and some parts are still supported by the manufacturer. I'm assuming you just purchased this grill and are in the process of assembling it according to the Owners Manual. So, if you continue to have a problem contact Brinkmann's Customer Support Hotline 800-527-0717.
Hope this helped you. Please let me know. Thanks.
1helpful
I threw the brinkman pro-series 810-8535-sb manual away by mistake. Can I print one via online?
I don't see a 810-8535-sb manual online. However, you can get the manuals for other Brinkmann Pro-series grills from their website: http://www.brinkmann.net/my_grill.aspx . The 4 burner 810-8533-S seems like the closest match. The direct link for this manual is: http://images.brinkmann.net/docs/pdf/810-8533-S.pdf . If you wait a while, the manual for the 810-3535-sb may become available through the My Grill site.
I hope this helps.
Apr 19, 2011 • Garden
How do i install the rotisserie on my grill..it is a pro series 8534...there are no pre-drilled holes and there is no way of closing the lid on the pit while it is cooking,,there is a slot cut out on the...
Buy the Brinkmann Universal Rotisserie Kit model #812-7102-S for $49.95. It uses 2 screws to attach a bracket to the existing tapped holes in the grill. It was that easy! I purchased my grill and the Rotisserie at Home Depot.
Pro Series 2400: I can't light the grill. I
If you hear gas going to the burners then you need to clean your grill if you don't then it a bad regulator
Instructions on how to put a brinkman gas grill
It might be best to just contact Brinkmann's Customer Service Department first. They should be able to either send you a Manual with snail mail OR point you to a link where you can download a copy of the instructions needed. Good Luck!
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
2helpful
Lost instruction manual for Bravetti Model#TO285 toast/conv.oven
The same unit was marketed under the Euro-Pro name, with the same TO285 model number. The manual, as a PDF, as well some replacement parts are available at this link:
http://www.euro-pro.com/europro/default.aspx
Hope that helps.
Top Brinkmann Grilling Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
