If they are square cement power resistors they are probably 3-5 watt 300-500 ohm .... are there colored stripes on the resistors? those are probably grounding resistors, they usually are installed too close to the board, get real hot a bunch of times and then crack the solder welds. when you replace them bring up the height and make space under the resistor to keep it off of the board and put a little drop of silcone underneath to hold them in place.
Definitely need pics. I couldn't find a schematic but pictures would be necessary. One thing you could do if you can't get pics is tell us the band colors of the burned resistors...if they are thru-hole and not surface mount. Then check the resistance of each resistor and post that info as well.
Can you take a digital picutre of this? Sounds like the output jack shorted and drew lots of current (causing burned board). Take a pic and send it to me and I'll see what I can do.
THanks,
-mike
