I have a Maytag SbS that warmed up. When I checked everything, the compressor was warm, and there was frost in the back of the freezer. It had been making clicking noises for a long time, but now I realize that it stopped a few weeks ago. (lol). Anyway, I defrosted the freezor overnight and plugged it back in this morning. It's starting to get cool, but it will take a bit to see right? do yo think I may have fixed the problem or am I prolonging the inevitable repair bill?
The adaptive derost control has gone bad a very common issue. It will work a couple of weeks before its back to its frosting over. It just plugs in but to get to it you must remove the controls at top of frigde section in the back right corner held in by two scewrs.
Check if fan in freezer is running as well as fan by the compressor and the compressor itself. Check for any frost buildup on evaporator cover in freezer.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start. Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start. Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start. Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start. Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start. Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Normal
0
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
start.
check fan.
be warm
PROBLEM). Heavy frost indicates defrost problem.
PROBLEM).
PROBLEM).
start.
check fan.
be warm
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
check make sure compressor is running
