Kenmore 43142 Front Load Washer Logo
Question about Kenmore 43142 Front Load Washer
11F ERROR I JUST REPLACED THE DOOR LOCK PIECE, AND I WAS ABLE TO DO 2 LOADS, BUT NOW I AM GETTING THE 11F AND I CANT OPEN THE DOOR AGAIN. I HAVE TRYING PRESSING THE STOP BUTTON BUT IT DOESNT WORK. WHAT IS THE PROBLEM NOW. PLEASE HELP.
Posted by Lilian Diaz on
  • Anonymous Dec 01, 2007
    11f code on washer
  • Anonymous Oct 12, 2008
    i'm getting the 11f message?
Anonymous
    Master:
  • 619 Answers
Door lock sensor broken/need to replace.
Posted on Jan 09, 2008
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
15helpful
3answers
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
1helpful
11F
error code?
F11 is a serial communication error. Could be as simple as a loose or faulty wire harness, bad drive component or more complex like a failed MCU, CCU or even the motor. I wouldn't rule out the door lock assembly either. There ain't a whole lot left in these machines!
16helpful
6answers
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
My front loading washer wont start it flash E and DL i dont no what it means can you pls help me?
DL means door lock error. This happens when the door trys to lock 6 times but cant lock.
There a 2 things that create this problem. the door lock mechanism or the CCU ( central control unit )
Replace the door lock mech. first. if this does not fix the problem replace the ccu.
Washer stopped and will not drain ...... Shuts off
if there is nothing in pump replace it ,door will unlock when error code is fixed on 2nd person if its not your pump its your ccu board top rear ,to open door take off bottom panel 3 star screws put hand up inside under lid switch there is round plastic tab pull down while opening door its a release cloths "less soap plz "
2answers
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
3helpful
2answers
Whirlpool washing machine model GHW9460PWO, error code 11F
Yes it may be in the MCU but I had one do this and it was in the CCU. Has it ever thrown a Fdl ??? Door lock code?? Thats another sign its in the CCU
tina gallow
