After HI start attempt, nothing will happen if I immediately try again. Wait a few minutes, the problem & failure can be repeated. Control panel works fine. Both starting capacitors have been removed and tested to the MF rating on the case. Relays on control board have been replaced with new.
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
SOURCE: H53SP-24 pool cover water pump: Pump quit; circuit
I have the same issue. I pulled the pump from the assembly and bypassed the circuit board inside by creating a circuit with the 2 black wires...pump worked fine. Of course, it won't cycle on and off so my guess is that the pressure switch somewhere in the circuit board is bad. Rule has a great warranty as my current unit is a warranty replacement (2 years ago). Last unit had a stamped date code on it. I contacted tech support ( [email protected] ) and got a new one sent out. The replacement did not have a stamped date code, so my fear is that they won't replace this one. I picked one up online for $99 and free shipping. If I get resolution on the broken on, I will have on as a backup.
Good luck and if yours is less than 3yrs old, contact tech support.
