SOURCE: 2004 Ford explorer will not start
Sounds like connections or cables. They may appear to look good but if they are aftermarket terminal ends they get corrosion under the bolt down clamp that holds the wires in. If they are factory cables that are molded on to the ends of the wires the same thing can happen. The easiest and cheapest thing to try is to put aftermarket terminal ends on the cables. Make sure you wirebrush the ends of the cables after you strip them and tighten them evenly and securely. Also clean the battery side thoroughly. If this doesn't work check the starter relay. Its the first place the red cable bolts to after the battery. Check the connections and try putting a jumper wire between the battery positive cable and the small terminal marked with an "S". One of these solutions should take care of this.
SOURCE: 1999 Chevy Lumina won't turn over...new battery
If your lumina has a Pass II key, it may well be the ignition lock cylinder on the steering column. The car key has a resistor staked on the sides of it which is read by the theft deterent module. The theft deterent module issues a command to the ignition relay and the fuel injectors when it reads a correct resistance from the key. If the lock cylinder is damage( broken wire) ect. the theft deterent module will not be able to read the key. Unfortunately, if you have a Lumina with a solid shroud around the steering column, the dealer will charge you $700-$1200 to replace the cylinder.
Good luck
SOURCE: nissan terrano 1996 td27 charging issue.
Did you hear the one about the Terrano with a charging problem?
Just fix it by replacing the thermostat!
Seriously - check your temperature gauge does it take ages for the needle to barely get off cold? (and is the heater useless?)
The needle should get to just below half way in 2 or 3 minutes.
If the thermostat is stuck open, then the engine does not get up to temperature.
The glow plug control senses the engine temperature is cold, so the glow plugs stay on for an extended period of time (sometimes 10 to 15 minutes) - short trips particularly in winter, with more headlight driving - the alternator can't keep up with the current being drawn off and from time to time you will end up with a flat battery!
A thermostat is cheap, and easy to replace (three bolts and about a half litre of coolant - I pumped the coolant from the top of the radiator, and didn't spill a drop when the thermostat housing was removed).
Sure enough, as the engine temperature reached about 50C, the glow plugs turned off.
SOURCE: Misfire and check engine light-flashes 12 times
There is a dead cylinder, so its not getting a spark at one spark plug. Check it at Autozone for free, that will tell you where the trouble is.
SOURCE: Ford 2005 E350 econoline van has had a battery light problem
you have a voltage drop.fine the damaged wire going fro mthe positive terminal of your battery to your alternator.fix this or it will keep working the alternator and draining your battery.
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in
few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
Click
this link below and follow the troubleshooting:------
This will help.
Thanks.
