When shortcut icon is double clicked, I get an error message window that states Roxio Creator has encountered a problem and needs to close. When I click on the error report, everytime I get this message:
Error Signature
Event Type: clr20r3 P1: roxiocentralfx.exe P2: 4.12.0.0 P3: 48a05348
P4: roxiocentralfx P5: 0.0.0.0 P6: 48a05348 P7: 106 P8: 50
P9: system.typeinitialization
It also states that this problem occurred: the operating system version and computer hardware in use: your Digital Product ID which could be used to identify you license, and the Internet Protocol (IP) address of your computer.
Any idea of how to eliminate this problem.
Mine did the same thing, i called dell , they could not fix 7 techs tried and failed. so i went to http://support.roxio.com and download creator 2009 service pack 4 (52.5mb) u have to register it first, then download . follow the instructions . mine works now.
SOURCE: I get an error in Creator Classic
I'm not sure what the problem is. Does it happen regularly? If it is regular make a note of any actions you take before the error occurs.
Check to see whether you have the latest updates for your software.
Also check on line to see whether any other uses have a similar problem check on any forums...
Roxio may have their own forums or be able to assist with your query.
Failing this you may solve this by uninstalling the software and reinstall it this may do the trick.
Kind regards
Alleluia
Had already done that with the same results.
