Replaced batteries in Harmony 670. Does not work shows "Safe Mode
After replacing batteries, remote screen shows "Safe Mode". there is no green light now so cannot change program on TV screen. Cannot even turn off!
Help!!
Re: Replaced batteries in Harmony 670. Does not work...
Update the firmware:
- Launch the software.
- Connect the remote.
- Click "Downloads"
- Click "Firmware."
- Update the remote.
That will get the remote out of safe mode.
The following troubleshooting steps might get your Harmony Remote working again!!! It is what the Logitech customer care gave me to do and it worked perfectly!!! Hope it works for you too!!!
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting. 2) Ensure you have the latest version of the Harmony Remote Software (7.7). 3) Update the firmware on the Harmony Remote. The following link shows how to complete this task: http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747 4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this: a) Remove the battery from the Harmony Remote. b) Press and hold the power button while reinserting the battery into the Harmony Remote. c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
Have you misplaced your Logitech Harmony 670 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 670 Remote Control Users Guide? Follow this link to download a pdf version of the operations manual.
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode. Did this fix the problem? If no, please continue to troubleshoot. ANSWER: 2. Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot. ANSWER: 3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot. ANSWER: 4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration. Did this fix the problem? If no, please e-mail us back for further information about your issue. ANSWER:
FIRMWARE: 1. Log into the Logitech Harmony Remote Software on your computer 2. Click on the Downloads button at the top-right corner of your screen 3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote 4. Once the firmware upgrade is complete, click on the Update Remote button 5. Test your remote.
Hi. Here is how to get your remote out of safe mode.
1. Connect your remote to the computer. 2. Launch the Harmony Remote Software, and log in. 3. Click "Downloads" at the top and click "Firmware" 4. The remote will go through the firmware update. 5. Select "Yes", and click NEXT to update the remote.
Once installed, you will simply
run the program and select
the devices you would like to control from
menus. This program finds the
right codes for you and loads them into
your remote control.
same exact thing 4 me!!!!!
