Goodman GMS90703BXA Heater Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Goodman heats but defrosts turns on before desired temp.
After about 3 or 4 minutes the defrost will kick on and blow cold air in the house till the defrost cycle is done. then the heat kicks back on. any temperature under 32 degrees i have to run emergency heat . my house is insulated very well and this is a new 3 ton 14 seer heat pump ,furnace and heat strips. the cooling worked excelent but is this normal for the heating part?????
Lou Barta
Level 2:
Novelist:
  • Expert 189 Answers
  • Posted on Mar 29, 2009
Lou Barta
Expert
Level 2:
Novelist:
Answers
189
Questions
0
Helped
82607
Points
297
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
1helpful
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Inside fan turns on when outside unit is in defrost mode when heat is selected. This causes it to blow cold air for about 10 to 15 minutes prior to the outside fan starting.
The inside fan will run while the unit is in defrost. The electric heat strips should kick on to help prevent you from feeling this cold air. When the unit is in defrost it is essentially running in the A/C mode. You should make sure the electric heat elements are working then go from there.
Hot air blows when system turned to heat, when control is moved to Defraost or combination heat/defrost air temp cools down, what could cause this?
Make sure you have the heat selection set all the way to heat. In Ford and Dodge vehicles, when you select Defrost the AC compressor actually kicks in and if you have the temperature selection set to the cool side it will push cold air to defrost your windshield.
Driver's side defroster and heater vents blow cold air but the passenger side blows hot. Both sides should blow hot The temp is set any temp and it still does the same thing. It is winter so I don't know...
The doors that open and close in the heater control unit are ran by motors. It sounds like a motor has quit in yours. When turning on the defrosters the motor closes the door to the heat for the floor
3answers
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
My GE fridge won't stay cold. The freezer up top seems to be cold.
How to check parts
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
My refrigerator will not keep cold. cold air in freezer none in refrigerator.
OR ..
4answers
Goodman Air Conditioner not heating well...
Heat pumps in cold climates suffer a number of limitations stemming from the fact that they are designed for air-conditioning applications. As climates become cooler and heating becomes more of the primary HVAC function, one may find that conventional heat pumps lose capacity and do not satisfy the load of the conditioned space. In colder temperatures, a conventional system’s need to defrost can further detract from heating performance. The use of resistance heat or fossil fuels to supplement or replace the vapor cycle. The additional use of supplemental heat to temper cold air blowing into the space during defrosts. As it gets colder outside, the delivery air temperatures inside begin to fall when no supplemental heat is being used. Supply air temperatures that are warmer than the return temperatures add heat to a space, but discomfort occurs when these supply temperatures drop below skin temperature. The air movement can feel cool or even cold. While the heat pump may be operating exactly as intended,the consumer will desire a more comfortable environment.
Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
