Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Rolling horizontal lines on 62" Mitsubishi
I am having rolling horizontal lines on my 62" Mitsubishi model number WD62725. I cannot make any part of the normal picture. I do have good audio.
I was watching the tv when it started. At first it was partial vibrating lines and it continued to getr worse.
How do I fix?
  • Mitsubishi Master
  • 8,617 Answers
That problem is caused by failed Capacitors on the signal and FMT power boards. which is a very common problem for mitsubishi TVs. There are repair kits available for the V26 dlp which contain the capacitors and instructions on how to do the repair. Heres a link check under the repair kits category.
http://servicemanuals.vstore.ca/
Posted on Mar 29, 2009
Service manual mitsubushi wd62725
Tvrepairkits.com is a very good source for service manuals. If you don't see one for your model you can contact Ed to get see if he can get a manual for your particular model.
May 08, 2012 | Mitsubishi WD-62525 62" Rear Projection...
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
My 2005 WD62725 just started getting wavy lines on it. Everything works good (i have picture and sound and all functions) but the lines started first only when a non-HD signal was coming in. Now it has...
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
No picture, no sound
The green steady power light is a good thing, how old is the TV?
If you are routing your audio and video through the audio receiver, make sure that the inputs are correct on the display of the receiver, ie. IF you are planning to watch your DVR and it is hooked up on Component 1 for video and Coaxial 1 for audio, make sure that the receiver is still programmed for this in the input of TV/Video 1 or whatever the input. I have ran into this on countless occasions, simple fix, but a headache until it is tracked down. Double check the connection to the TV as well.
Nov 25, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Tv problem mitsubishi wd62725 ir location
This remote device works on pulsed IR beams to work, and the fact that the screen refreshes very close to the speed of the controller could be causing the reliability problem..Sorry I don't have a better solution for you....accordianman
Nov 11, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi VS-50705
VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Sep 16, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
567 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
