HP OfficeJet 4215 All-In-One InkJet Printer Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Officejet 4215 will not print
Downloaded and installed current Vista compatible software from HP site (with tech support assistance). Printer power is on, USB in proper port, and control panel indicates 4215 as default printer. Print jobs qeue up but....no print.
Anonymous
Level 2:
Scholar:
  • Expert 34 Answers
  • Posted on Apr 27, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
34
Questions
0
Helped
17011
Points
105
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
1helpful
Hp officejet 4215 all in one, upgrated from windows vista to windows 7 and also upgrated from 32 bit to 64 bit, need installation driver for this hp officejet 4215 printer scanner.
Brows the link.This Windows 7 patch fixes some printer functionality after upgrading Vista to Windows 7. Link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=351106#N221
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
6answers
HP 4215 not working at all
you need to install a driver compatable with vista.
4answers
I can not install my hp officejet 4215
have u gone on the HP web site and checked for updated software? I have 2 HP printers and both had issues, downloaded the newest software at HP site support and cured the problem.
2answers
I lost the Cd to instal my hp printer to my computer
Here is a link for the 4215. Links are on this page for software downloads, manuals, etc.
4215 Support Page
Hi this is randy
If you do not have the disk you download software from Internet, follow instructions below,
Click here:Drivers and Software:HP Officejet 4215
A web page will open, follow instructions, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, if you get introubles ,thenfollowinstructionsbelowto reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some printer does not work on Vista.
44helpful
4answers
Scan using the HP OfficeJet 4215 Printer
The problem is with Windows Vista...it does not recognize the scan button when you touch it on the scanner. There are two ways around this:
Go to Programs / Windows Fax & Scan / Click new scan / click file and then click scan
OR
Go to Accessories / Paint / Cick File /click from scanner or camera / click scan
Print spooler when installing HP OfficeJet 4215 All-In-One
go to control panel, administrative tools, services, and turn it on.. hit start and set it to automatic.
7helpful
3answers
Hp officejet 5610v all in one insallation software for windows vista
Try this link. It is the full intall file for the all in one being run on a Vista Machine. It worked fine for my installation.
Muck around on the site for a bit, and you can also find the same install file for Windows XP.
Good Luck
http://hp.driversdown.com/hp-drivers-download/HP-Officejet-5605-5610-5610v-5610xi-All-in-One-Driver-080.001.237.000-for-Windows--Vista-(32-64)_9168.shtml
Hp officejet 4215
Hello sonyamac,
You can download the software directly from the manufacturer and install it without the CD. Go to www.hp.com/, find and click Software & Driver Downloads, select Download drivers and software, type officejet 4215 in the box and press enter. Select which officejet matches yours: 4215, 4215v or 4215xi (you can find that info on a label attached around your printer. Sometimes the model is only described as CXXXXA format. If that is all you got, go back to the prior page and type that model instead of officejet 4215. You should reach a page where you select which operating system you are using, click on it and on the next page you can select which software you want to download. After saving your download, just open the program, follow the installation instructions and you should be ready to print in no time. Hope this helps.
cancerags
k24674
Grand Canyon Tech
Grand Canyon Tech
