Samsung RS2534 Side by Side Refrigerator Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not getting cool water from dispenser in door
Would apprec. yr advice on why water is not cooling - the side by side fridge is brand new.
Anonymous
Level 2:
  • Expert 42 Answers
  • Posted on Mar 29, 2009
Anonymous
Expert
Level 2:
Answers
42
Questions
0
Helped
10269
Points
109
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
458
Points
Water from dispenser will not be chilled . Cold water supply from dispenser will depend upon capacity of water tank located inside the freezer door or behineed the veg box.Normally it remains to be 1.1 lt to 1.4 lt. . It means if we take 200 ml glass of water in first supply tempratyre wud be approx. 12~14 degree & for next glass temp will be approx. 14~16 degree because as soon as you dispense few quantity of water automatically fresh water supply starts inside the tank.So if you are taking approx. 4-5 glass of water all glass will have different temrature of water ranging between 13 to 18 degree. It takes approx. 6 hr. for whole water tank to get temp of 13~14 degree again
My side by side fridge isn't cooling. Lights on the inside of the fridge will come on, but on the door where the ice/water dispenser will not work.
before you spend a lot defrost/ unplug. lets the ice in the crossovers melt. plug it back in and see what you get.
mike
My ridge is a side by side and the friser is working but not the fridg side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
3helpful
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
My water dispenser in my GE refrigerator does not dispense water. The same lever that dispenses water also dispenses water. I have checked the ice and water selenoids and they are working. The cooling coil...
We have an Electrolux Wave Touch with the same problem.
1 yr later, 3 new fridges, 1 new freezer door and no solution.
Yes, the line is clearly frozen inside the door.
Disconnect waterline at bottom of freezer door and activate solenoid - then you know for sure.
New fridge not cooling
Check the warranty, call the company.
1helpful
3answers
Warm Water out of water dispenser
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
