Question about Casio Watches
Casio Pathfinder PAG-50 battery replacement
This problem is regarding CASIO Solar Triple Sensor Pathinfinder wrist watch (PAG-50).
A few months back, the battery in my watch died. It would charge when kept in the sun, but discharge in a few minutes. I took it to a Watch Station store and they said the battery is dead. They could not acquire the CTL1616 cell that the watch needs.
Last week I found the battery on eBay and replaced the dead battery as per the instructions at:
http://forums.watchuseek.com/showthread.php?p=296572
After replacing the battery, before closing the back of the watch, I looked at the display and it had the LCD segments ON. It showed 12:00 time and the seconds were ticking. The word 'charge' under the battery symbol was blinking and 'open' was displayed at the bottom of he display.
After closing the back, however, the display went blank. Even after keeping the watch under a light for hours, the battery won't charge even a little bit.
If I open up the back again, the LCD segments turn ON again, and all that I mentioned above happens. But when I replace the back, everything is blank again.
I wonder what the problem is. Is it really a dead battery? or something is causing the battery to drain - something like a short circuit. Should I just give it more time to charge?
Any pointers/insight would be greatly appreciated.
Thanks
Anonymous
    New Friend:
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Posted on Nov 08, 2010
Paw-1200t
may be some dust inserted into the watch which prevents you to press the buttons .
another prob might be low battery. put your watch in sun in order to give some power to your solar battery
Nov 11, 2013 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
The word "LOW" always appearing
The word LOW means that the solar battery charger is not charging. This could be a defective charger or you're not out in the sun long enough to keep it charged.
Feb 06, 2011 | Casio Protrek Triple Sensor Tough Solar...
Casio solar 2471 wont charge or recover
Thank you for contacting FixYa.
You will want to contact Casio on this.
The link is here
http://www.casiosalesandservice.com/repair.htm
Best regards. Jewel
Sep 01, 2010 | Casio Protrek Triple Sensor Tough Solar...
I have model 2271 PAG 40 it seems to be stuck in some kind of display mode. switching from comp to baro to alt.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
My Casio Pathfinder PAG-50 when I go into compass mode shows ---* is there a way to set the compass?
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Jan 01, 2010 | Casio Pathfinder Triple Sensor PAG501V...
Not very helpfull
Because it is not a documented problem for this watch in the user manual to be found at http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2767.pdf
Are you sure you acctually have a Casio Protrek Tough Solar Ana-Digi PRG-60T unit or do you perhaps have some other model of Casio watch and have posted in the wrong place on the forum?
Jan 17, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
I have a casio triple sensor solar watch (prg-50). It constantly reads 'Open'. Does this mean the battery is dieing??
Casio solar watch has no battery it is powered by solar,but there is a storage capacitor like a battery.It will last for 5years that capacitor.Try to hold all the buttons and press hold simultaneuosly for 7 seconds this for reset the watch..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE.
Jul 29, 2008 | Casio Watches
Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Jun 20, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Watches Logo
5,162 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
