Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
Ps2 joystick or ports problem.
Hello, my ps2 responds a second later after i push a command. its delayed. this happens for both ports or joysticks and or ports. any suggestions. please help.
Posted by hpspol on
Anonymous
Maybe you need a new controller that happend to me one time.
Posted on Mar 29, 2009
Anonymous
    Problem Solver:
  • 5 Answers
I have a problem with ps2 joystick keys not working
Posted on Jul 01, 2009
I just hooked up Atari 7. Only one joystick works. any suggestions
unhook the working joystick and put the non working joystick in it. Tell me what happen next...
Nov 18, 2017 | Atari Video Game Consoles & Games
Tip
Installation, and testing the Logitech Extreme 3D Pro Joystick
The joy stick comes with a CD. Put the CD on the tray, and let the computer runs the software. On the CD there are driver for the joy stick itself, and driver for the USB . click on install joystick, after that, click on install the USB drive. that is it. Then a test screen will appear and asks you to check your joystick movements and buttons .push on the buttons,on the joystick, and you will see that they turn red on the computer screen each time you push a button, meaning your computer reads the commands from the joystick, You are set.
If you do not have the CD, then go to the Logitech site. and go to support, and from there you can download the drivers for the joystick.
on May 04, 2014 | Logitech Extreme 3D Pro Joystick
Hi, I have 2 PS2 controllers, the one was newly bought, the other, has been used for about a year or two. The problem is, the old one's R1 button is unresponsive. Well, it do responds, but only if...
you will need a rubber replacement for your R1 button, if you or a friend have a defective joystick consider that a replacement. if you can't find a defective joystick you can buy a ps2 rubber kit online. below are reference pics.
1. Remove 5 screws with a philip screw at the back of the joystick.
2. Split the two covers with caution.ck
3. Carefully remove the rubber beneath the R1 button and replace it with a new one.
4. Put together the front and back part of the joystick.
5. Test the replaced part and screw if you're satisfied.
Hopefully this information helps.
Thank you for using Fixya..
Aug 03, 2011 | Sony PS2 Dual Shock 2 Controller...
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
How or where is the L3 button on Playstation 2?
the L3 R3 are the joysticks! push down on the joysticks like buttons much like how you zoom in sum games its that,
Jan 10, 2010 | Sony PlayStation 2 (PS2) Console
Both my joystick are not working
Try Other Games... If That Still Doesn't Work Loan An Additional Joystick Just To Check If It's Joysticks Fault, If The Additional Joystick Doesn't Work Then It Must Be A Broken Port Or Something...
Nov 21, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 not responded to my joystick my joystick is work what happen my ps2
The Cable could have a break in it, check to make sure none of the pins in the Controller port are bent and if all else fails you will need to buy a new controller port, but try a different controller before you buy a new controller port
Nov 03, 2009 | Sony PlayStation 2 (PS2) Console
PS2 Controller Joystick Problem During Gameplay
If you've had the controller a long time weird things can start happenning. Usually the pads on the joysticks go first.
Try a different joystick(borrow a friends) and if it still happens you'll know its not the controller.Could be a glitch in the software of the game.
Eliminate each area. If a friend has the same game use their disc to try your controller with.
Take your controller to the video game store ask them to try it out on their game display models.If it's "busticated" you can buy a new one right away LOL.
Aug 03, 2009 | Sony PS2 Dual Shock 2 Controller...
Playstation 2 joystick do not work
your PS2 console 3.3volt chip damage you repair PS2
May 14, 2009 | Sony Video Game Consoles & Games
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
751 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
