Samsung YP-U2JQB MP3 Player Logo
Posted on Aug 27, 2007
Cannot install the device
When i try to install it, it keeps connecting and disconnecting and my computer won't recognize it. It says it has found new hardware, but then tells me the device is not working properly. says there's a problem with the driver. I've already downloaded firmware and that keeps telling me to "please connect device"
  • 2 more comments
  • Anonymous May 21, 2008
    cuando lo meto dice que no lo reconoce pero si escucho musica, pero tengo trabasjos ahi y no lo lee para abrirlo
  • Anonymous Jan 12, 2009
    same thing
  • alkennedy Jan 24, 2009
    exact same problem
  • Anonymous Apr 17, 2009
    its reli annoyin coz wen u plug it into the computer it charges but the computer doesnt recognize it? does anyone know wot to do ?
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Sep 02, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
9345
Points
19
With regards to this issue, I would suggest you to download windows update since samsung MTP devices are generic driver loaded by microsoft. Then after you have downloaded the windows update press and hold the play button of your device while you are connecting it to your computer, if this is successful a Found new hardware message will pop up on your screen then just follow the on screen instruction on how to install your device. Hope this helps. PEACE!
1 Related Answer
A
Anonymous
  • Posted on Aug 10, 2008
SOURCE: Found New Hardware MTP Device. Pop-Up
Try changing mp3 firmware to MSC mode.
MTP is a protocol developed by Microsoft that just sucks and makes one million of help requests like yours.
2answers
How do I have the computer recognize the device? I have intelliroute 710.
You need to install the dock software: http://www.randmcnally.com/support/s/dock-software. Just find the one that will work for your computer.
3helpful
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Replacing HP 7580 all in one scanner fax with HP 7590 all in one scanner fax. I did not have install CD for 7590 so downloaded drivers from HP site. Error message keeps saying that does not recognize...
first Step - Try another USB Cable.. If this does not solve, try the steps below.
Power off the Printer
Disconnect the USB Cable from Printer to PC ( from PC )
Disconnect the power cord of printer frmo wall outlet
Power off the PC
Disconnect the Power cable from back of PC and from wall outlet as well
wait for 10 minutes
Connect the PC power cables to PC and Turn on the PC
When you login to your Desktop, Turn on the Printer
Connect the Cable,
It should get recognised.
Regards,
Ron
1helpful
MY SANSA ISNT RECOGNIZED BY MY PC!
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa )
Go Gear is not recognized by computer
You must roll back to WMP 10 - this device is completely incompatible with WMP11 - instructions are on both the Philips and Microsoft websites
After rolling back to 10:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Player frozen..
You need to do two things - the first tactic will force the computer to recognize the GoGear - the second will fix the device:
Disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
After this is done, open the Philips Device Manager that came with the install CD, and run a "Repair" - the instructions will be remarkably similar to what we did before.
The do a "update" in the Philips Device Manager to be on the safe side.
-Tha Mp3 Doctor
My creative zen sleek photo mp3 player is not being read by my computer.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Sansa e-260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Computer does not recognize device
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
No device recognized when connected to computer
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
