Overhead dvd player was working fine then one day a problem..video plays on the screen but the sound is only crackle noise on both head sets. We have since tested another new headset and ruled them out as the problem. car electronic shop says it seems the repeater? is not sending the signal properly. they dont repair overhead dvd players. any ideas how to fix this possible problem?
SOURCE: XOD1736
This is a problem with break wire. I too expierienced this. It is NOT a problem with radio. You need to ground the break wire in the harness. It is a protection wire so that it knows the emergency break is on. In other words it is supposed to stop you from watching movies while driving. Grounding the wire disbales the feature thinking the break is on. If you want to use the safety feature properly it should be connected to the emergency break switch that is grounded when pulled up or on.
SOURCE: XOVISION CAR DVD PLAYER SOUND NO PICTURE
hook your brake line wire from stero to your ground wire. it needs to be grounded
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
SOURCE: I purchased the Xovision 9
No you have to remove that cardboard. It protects the laser in transit I guess.
