HP LaserJet 4 plus Printer Logo
Posted on Mar 28, 2009
Paper turns gray
When printing the white paper turns gray. Cannot figure out how to take toner out of the drum
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
598
Points
It is written in the Manual:
If the amount of background toner shading becomes unacceptable, the procedures described below may help to clear the condition:
* Increase the density setting. This will decrease the amount of background shading.
* Change the paper to a lighter basis weight.
* Check the printer's environment' very dry (ow humidity) conditions can increase the amount of background shading.
*Replace the toner cartridge.
*Replace the transfer roller
i hope it can help.
Regards,
sabeteh
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
HP LaserJet 1007 Prints Light
First of all check your printing preferences
  1. Right-click the product icon, and click Printing Preferences to open the Printing Preferences window.
  2. Click the Paper/Quality tab.
  3. Check the paper or media type setting.
    1. Find the Type is: drop-down list.Figure 1: 'Type is:' drop-down list in the Printing Preferences windowc01855301.gif'Type is:' drop-down list in the Printing Preferences window, Paper/Quality tab (screenshot)
    2. Select the paper or media type you are using.
      • For thinner paper, select Light , Thin , or Vellum .
      • For thicker paper, select Heavy or Thick .
      NOTE:HP does not recommend the use of heavily textured paper, extremely thin paper, or paper with a basis weight heavier than 90 g/m2 (24 lb).
  4. Make sure the paper or media type setting is appropriate for the fuser temperature.NOTE:Unlike ink printers, laser printers use heat to fuse a plastic toner to the surface of the paper. Make sure to use heat-resistant paper, and labels and envelopes that use adhesives compatible with the heat and pressure of the product's fusing process.
    1. If you are experiencing any issues in the following list, adjust the setting.
      • If the paper is curled or wavy , try the following:
        1. Decrease the fuser temperature setting. To do this, select Light ,Thin , or Transparency .
        2. Use the archive print feature to improve toner fusing. To do this, select Archive or Bond .
      • If the printout has areas of fuzzy or dark print , or toner scatter , increase the fuser temperature setting.
        1. Select Heavy or Thick .If this does not resolve the fuzzy, dark print, or toner scatter issues, use a lower basis weight or thinner paper.
  5. Click Apply .
Step three: Check the print density settingsFollow these steps to check the print density settings in Printing Preferences and in Properties.
  1. In the Printing Preferences window, click the Paper/Quality tab, and find the Print Quality section.Figure 2: 'Print Quality' section in the Printing Preferences windowc01855302.gif'Print Quality' section in the Printing Preferences window, Paper/Quality tab (screenshot)
  2. If you are experiencing any issues in the following list, adjust the settings.
    • If the entire page is too dark , change the dpi setting, and turn on EconoMode .
      1. Select 600 dpi from the drop-down list.
      2. Select the EconoMode check box.
    • If the entire page is too light , change the dpi setting, and turn off EconoMode .
      1. Select FastRes 1200 from the drop-down list.
      2. Clear the EconoMode check box.
  3. Click Apply , click OK , and then close the Printing Preferences window.
  4. Open Printer Properties. To do this, right-click the product icon, and click Properties .
  5. Click the Device Settings tab, and find the Print Density section.Figure 3: 'Print Density' section in the Properties windowc01855303.gif'Print Density' section in the Properties window, Device Settings tab (screenshot)
  6. If you are experiencing any issues in the following list, adjust the setting.
    • If the printout has areas of gray shading or a gray background , decrease the print density setting.To do this, slide the bar to the left .
    • If the printout has light, dull or faded areas , increase the print density setting.To do this, slide the bar to the right .
  7. Click Apply , click OK , and then close the Properties window.
  8. Try again to print.If these steps do not resolve the light, dull or faded issue, the print cartridge is almost empty. Skip to Solution eight: Replace the print cartridge .
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.If this don't help you, here is instructions for refilling a toner cartridge.
http://www.uninetimaging.com/downloads/technical/hp/english/HP_P_1006_Reman_eng.pdf
Maybe you need to clean the drum, blades or the developer roller. Maybe the problem is in the toner you use.
3answers
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
I loaded a lined sheet of notebook paper into our printer tray to have something print on it. It came up with the message that there was a paper jam and to remove the paper tray and toner cartridge. I...
The only way a paper jam could affect your print quality is if it were actually stuck in the toner/drum cartridge area. I would remove the drum unit and then take the toner cartridge out of the drum unit and make sure there is no paper in either of the 2 units. The only other possibility would be that the sheet of paper wrapped around the fuser roller. This is the area just before the paper exits the machine. This would usually cause the print/toner on the copy to rub off or not be fully "fused" onto the page.
Good Luck and Thank You for using Fixya.
Print quality is poor. I hace cleaned corona wire and poblem is still there. Entire page is streaked with black. White paper comes out gray. What else can I do? Should I change the toner cartridge?
If you have a old drum or old toner cartridge switch them and see if it goes away. Other wise start with a new toner cartridge. I sell them for 40.00 and the drum for 60.00. Steven 818-888-0006
3helpful
2answers
I am unable to print to my HL-4040cn printer. I tried to print a the printer settings from the menu and I get a {RED} Print Unable E1 message on my 4040cn. I tried off and on several times. Same problem. ...
Follow the instruction below to clear this error.
Caution DO NOT use flammable substances or any type of spray to clean the inside or outside of the machine.
  1. Power off the printer using the On/Off switch located on the right side of the printer.
  2. Press the front cover release button and then open the front cover.
  3. Pull out the drum unit as follows:
    • Hold the green handle of the drum unit. Lift the drum unit up and then pull it out until it stops.
    • Release the gray lock lever (1) that is on the left side ofthe printer. Pull the drum unit completely out of the printer using thegreen handles on the drum unit.
      Caution Hold the green handles of the drum unit when you carry it. DO NOT hold the sides of the drum unit.
      Caution
      • We recommend that you place the drum unit on a clean, flat surfacewith a piece of disposable paper underneath it in case you accidentallyspill or scatter toner.
  4. After the drum unit has been removed, carefully look inside the printer and remove any paper, scraps of paper or labels.
  5. Remove the 4 toner cartridges fromthe drum unit. Hold the handle of the toner cartridge and pull it outof the drum unit. Repeat this for each of the toner cartridges.
    Caution We recommend that you place the toner cartridgeson a clean, flat surface with a piece of disposable paper underneath itin case you accidentally spill or scatter toner.
  6. There will be four open slots on thedrum unit where the toner cartridges were installed. Examine theopenings and the black roller in each slot for pieces of paper orlabels and remove them. Also inspect the right and left sides of thedrum unit for pieces of paper or labels.
  7. Turn the drum unit over and check for pieces of paper or labels that may be stuck in or on the black rollers.
  8. Turn the drum unit back over and reinstall the tonercartridges. Hold the handles of the toner cartridges and then slidethem into the drum unit. Make sure you match the toner cartridge colorto the same color label on the drum unit. Fold the toner cartridgehandles down once the cartridges are in place.
    1. C- Cyan, 2. M- Magenta, 3. Y- Yellow, 4. K- Black
  9. Hold the green parts of the belt unit with both hands and liftthe belt unit up, then pull it out. Check the bottom of the belt unitfor paper that may be stuck to the belt surface.
    Caution We recommend that you put the belt unit on a clean, flat surfacewith a piece of disposal paper underneath it in case you accidentallyspill or scatter toner.
  10. Remove the waste toner box from the printer using the green handle.
    Caution Handle the waste toner cartridges carefully in case you accidentallyspill or scatter toner. If toner scatters on your hands or clothes,wipe or wash it off with cold water at once.
  11. Look inside the printer, especially towards the back, forpieces of paper or labels. A piece of paper or label may be stuck nearthe roller located deep at the bottom of the printer. Check the rollerand remove any paper or labels in the printer.
    Caution
    • DO NOT use a sharp object to avoid the damage of the roller. It may cause the printing problem.
    • DO NOT touch some internal parts shaded in the illustrations. Those parts will be extremely hot after you have used.
  12. Put the waste toner box back in the printer using the green handle.
  13. Put the belt unit back in the printer. Match the down1.gif mark on the belt unit to the up1.gif mark on the printer.
  14. Put the drum unit back in the printer as follows.
    1. Make sure that the gray lock lever (1) is in the up position andput the drum unit in the printer. Push down the gray lock lever (1).
      Note When you put the drum unit in the printer, match the green guides(1) of the drum unit handle to the green arrows (2) on both sides ofthe printer.
    2. Push the drum unit in until it stops.
  15. Close the front cover.
  16. Power the printer back on.
  17. Try to print again.
    If this error still remains, contact the Brother support center.
2answers
HPlaserjet P1006 Series When printing getting a white blank streak down the middle of the page
To isolate the problem you need to do a 'half test'. This involves printing and stopping paper half way through the printer. This can be done by opening the toner door at the appropriate time. The paper should have just entered the fuser (watch out, the fuser is HOT). You should see the paper with the printing on it after removing the toner cartridge. Carefully turn the toner cartridge over and move back the door that covers the drum. DO NOT TOUCH THE DRUM. If there is the corresponding blank spot in the center of the drum, like the paper, the scanner is dirty or blocked. A can of compressed air will help here. If you have access to a different toner cartridge, you may want to try that first.
Unwanted gray stripes on paper
Printer needs a good clean and service.
Toner particles have probably split onto the fuser drum or has been contaminated by previously printed paper losing some toner.
As the particles get re-heated, they become waxy and smear around the drums and rollers.
For stripping and cleaning procedure, check the FIXYA manuals and tips, searching for your model, or similar one, or try a manuals download website and enter your make & model.
HP may also have the info.
You'll probably need a service manual rather than the user manual.
White paper no longer white
You are probably getting low on toner. Your printer also might just need a little cleaning. I would open up the front of the printer and take out the toner/drum. Wipe off the edge of the toner cartridge with a dry cloth to remove excess toner. Replace the toner cartridge and see if this works!
k24674
Grand Canyon Tech
Grand Canyon Tech
