Question about Whirlpool LER5636P Electric Dryer
My Whirlpool dryer belt broke.
Went in to replace the belt and found that the idler pulley was not connected. How do I replace the present one in place or do I need to get a new idler pulley?
Thanks for your help!
Posted by babzeann on
  • timothy4clea Mar 29, 2009
    REPLACE BELT ON WHIRLPOOL DRYER #LER5636P
Paulo
  • 188 Answers
You should be able to reuse the idler pulley unless it is physically broken.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Posted on Mar 28, 2009
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
Bolt backed out of idler pulley in my 2008 ford fusion what do I need to do to put my new pulley in
You need a serpentine belt tool, you can rent one at the parts place and while you are there get the new idler. You will also need a wrench to fit the bolt. Remove the belt then take the bolt out of the idler and install the new one, you can use some low strength loctite purple to keep this from happening again. Reinstall the belt, return the tool and get your money back for the rental.
Feb 17, 2014 | 2008 Ford Fusion
Replacing a belt
Replacing the Drive Belt
IMPORTANT: To aid in reassembly, note the orientation
of the drive belt on the two idler pulleys and the engine
flywheel pulley prior to performing the following steps.
Refer to Figure 10.
The edger drive belt is subject to wear and should be
replaced if any signs of cracking, shredding or rotting
are present. To replace the belt, proceed as follows:
1. Working in front of the edger, loosen the flange
lock nut on top of frame, allowing the idler pulley
assembly to pivot slightly out from the frame. See
Figure 10.
2. With your other hand, carefully reach under the
rear of the unit and remove the belt from around the
engine flywheel pulley.
3. Remove the spindle sheaves belt guard by removing
the two self-tapping screws which secure it to the
blade plate assembly. See Figure 10.
4. Carefully remove the belt from the pulleys,
again making sure to note the orientation of the belt.
Discard the belt.
Install the replacement belt (Part No. 754-04032B) in the
same configuration that the original belt was routed as
follows:5. Working from the front of the edger, place the belt onto
the spindle sheaves, route it back onto the two idler
pulleys, and then place it onto the engine flywheel
pulley.
IMPORTANT: Make certain that the "V" side of the belt
is seated into the top pulley and the flat side of the belt is
seated into the bottom pulley.
6. Reinstall the spindle sheaves belt guard with the self
tapping screws removed earlier.
7. Make certain that the drive belt is on the engine
flywheel pulley and idler pulleys, and retighten the
flange lock nut on the top of the frame.
IMPORTANT: Make certain that the drive belt is seated
correctly and that it is riding smoothly on the spindle
sheaves and is not pinched between them. Repeat the
first three steps if the belt is pinched.
You don't want the belt pinched between those spindle sheaves...trust me ;)
the manual
Oct 13, 2012 | Troy-Bilt tb554 lawn edger
Replace belt
  • Disconnect the power source from the dryer. You can unplug from the wall outlet, remove the fuse from the fuse box or flip the breaker in the panel box.
  • 2
    Pull off the front panel of the dryer. Remove the screw in each corner at the bottom of the dryer's front panel. Lift up the front panel until the two clips at the top disengage. Remove the two screws that are found beneath it at the corners to remove the cabinet top.
  • 3
    Remove the belt by releasing the tension applied by the movable idler pulley wheel. The belt loops over the drum, under the idler pulley wheel and then around the motor's drive pulley.
  • 4
    Discard the used belt. It is fine to just throw it in the trash.
  • 5
    Install the new belt by pushing in on the idler pulley arm. Make sure the new belt is placed flat along the exterior of the drum.
  • 6
    Replace the screws back into the dryer's front panel. Screw them in tightly so that the panel will not fall off or jiggle loose.
  • 7
    Reconnect the power source back to your dryer. Either plug it back in or flip the switch in the breaker box.
Jan 11, 2012 | Amana DLE330RAW Electric Dryer
Replace a belt on indesit dryer
Hello.
Tools needed to solve the problem
(A)Standard screwdriver,New belt
1 Unplug your dryer to disconnect power to the unit.
2 Remove the screws that hold the dryer top in place using a standard screwdriver. The screws are located along the top and sides of the dryer. With older models -- 1996 and older -- the entire top comes off the dryer. For new models, the timer and console stay in place while the rest of the top comes off.
3 Remove the screws that hold the front panel and door in place using a standard screwdriver. The screws are just inside the door at the top front left and right sides of the dryer. The front panel on older models will move to the right side and on newer models the door will move to the left.
4 Remove the existing belt by pulling the idler pulley to the right. This will take the tension off the belt and allow you to pull it away from the motor pulley.
5 Install the new dryer belt by wrapping it around the top of the drum and allowing it to fall around the circumference of the drum. The grooves of the new belt should face down toward the drum. Rotate the belt around the drum to ensure there are no twists in it.
6 Connect the new belt to the motor pulley. On newer models you can access the motor pulley on the front underneath side of the dryer. Pull the idler pulley to the right and loop the belt around it. On older models you can access the motor pulley through an access panel on the back of the dryer. Pull the dryer away from the wall and remove the access panel using a standard screwdriver. Repeat the same steps as on a newer dryer to install the belt around the motor and idler pulleys.
7 Replace the front panel of the dryer and the screws that hold it in place.
8 Replace the top of the dryer and the screws that hold it in place.
9 Plug the dryer in and make sure the belt works properly before trying to use the unit.
Thanks.
Nov 07, 2011 | Indesit W 123 Front Load Washer
I have a 2000 gmc Jimmy . I'm going to change the
Locate the idler pulley to the left of the crankshaft pulley. The idler pulley bolts to the idler arm. The idler pulley is replaced with the arm because they are sold as one unit.
  • 2 Place a 3/8-inch ratchet driver into the square hole on the face of the idler pulley and pull up on the handle. This releases tension on the Sonoma's serpentine belt. Pull the belt off the idler pulley, lower and remove the ratchet handle.
  • 3 Remove the two bolts that secure the idler arm to the engine block using a socket and ratchet, and discard the old idler arm.
  • 4 Place the new idler arm against the engine block and secure it using the socket and ratchet.
  • 5 Put the ratchet driver into the square hole on the new idler pulley, pull up on the handle and place the serpentine belt over the pulley.
  • 6 Lower and remove the ratchet handle.
  • Oct 15, 2011 | 2000 GMC Jimmy
    Cant get serpentine belt on my truck
    Try putting the belt on the alternator then slide it under the idler pulley last.
    Feb 23, 2010 | 1994 Ford Ranger Supercab
    Replace idler arm pulley
    An idler arm is a steering component found on vehicles without rack and pinion steering. Your referring to an idler pulley. To replace: remove the belt, remove the bolt from the center of the pulley, replace the pulley and reinstall the belt.
    Apr 11, 2009 | 1999 Dodge Intrepid
    Whirlpool LER5636P Electric Dryer Logo
    263 people viewed this question
    Top Whirlpool Dryers Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    John Tripp
    John Tripp
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
