Ok well i lost my remote for my tv so i ahve bean using my vcr but it takes up to much space so i found my old jensen universal remote (sc-540) but i cant find the code list if you can help me that would be great thanks ~JOHN~
I saw this on another site when looking for the answer for a friend.
http://www.tivocommunity.com/tivo-vb/showthread.php?t=233574
a.0091
b.
0155 is the Symphonic TV/VCR combo code
c.0053
d.0126
refer to the above site for more info. Good Luck to all and Happy Holidays!!!!!!
Posted on Dec 07, 2008
I got this off yahoo answers:Turn on your TV.
On your Tune In remote, press TV and release.
Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
Enter the first three-digit TV code for your Symphonic from the list which follows:
171, 179, 180
These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TV
Why test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
Coud you please send me your tv model so I would help you more!! Patrick
Posted on Aug 27, 2007
SOURCE: i have lost my tv remote for my syphonic tv
One website gives instructions on how to use the AUTO CODE SCAN feature of your remote, even if you don't have the code numbers. Take the following steps to access this info.
Step 1) Type REMOTECODELIST.COM into the Google searchbox, and click on GO or SEARCH.
Step 2) Once you are on the website, scroll down the page until you see JENSEN in big red letters, on the left hand side.
Step 3) Look under JENSEN for SC-540 ( in purple letters), and click on SC-540.
Step 4) Look on the right side of the page for instructions on how to do an AUTO CODE SCAN.
Hope this helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Posted on Jul 15, 2008
My Symphonic is a 13" and has a very good picture but I have no remote. I tried a universal but was not compatible. I hate to get rid of it because of the good picture, but it sure is a bear to try to get the channels changed. The Model # is ST413B and and was Mfgd. in July of 2001 and the Serial # is J27114703. Thanks. Ruth B.
I got a used Symphonic without the remote... I do have a "Oneforall" but need the code
I got a used Syphonic TV without the remote... I do have a "Oneforall"... I need the code thanks
i lost my remote and i cant get to my AUX channel
My name is Larry from alabama ,and i have a symphonic t-v model wf-13 and i lost my remote and i do not have the codes to try with my cable changer remote. What come with the guide for the code it dos not work. please help. Larry
I've bought two differant universal remotes for this tv and neither one will work. I can almost buy a new tv for what an original remote will cost. Do you know of a universal remote that's compatible with this tv?
