Question about La Crosse Radio Controlled Atomic Clock
Digital Atomic Clock WIll not receive signal or outdoor temp
I have 2 La Crosse digital atomic clocks. One is a wall clock and the other is a small projector alarm clock. At one point I had them both set to the same receiver, then I moved the wall clock and it lost the signal. So i reset both clocks and the receiver. The alarm clock still works fine, but the wall clock has never received a signal since (Time or Outdoor Temp). I followed the manual instructions, ensuring i reset both clocks, still no luck. please help
Posted by fatty0206 on
  • pas1541 Apr 11, 2009
    I have several of the laCross systems and ther all lose the out side signial more ofter then not . Have replace batteries so mant time I've lost count.
5 Related Answers
Anonymous
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
odysp
Cyprian Amaechi
SOURCE: atomic clock reception
I guess the battery has run out on you. change the battery and you are good to go. I got to warn you though, if you are skittish on taking a good risk, do not try to change the battery yourself. It is a little piece of complex machinery. I have the same problem a while ago. I decided to change the battery myself after the watch repairman tried to sell me a new watch. And you know what, I'm glad I did. My atomic watch is working fine again.
Posted on Nov 19, 2008
Anonymous
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
Anonymous
  • 714 Answers
SOURCE: AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Posted on Feb 15, 2010
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Posted on Mar 19, 2010
La Crosse Model W86111, Setting
an atomic clock ........ no user manual ?
1 Digital Atomic Wall Clock Model: W86111 ' Quick Setup Guide
pdfstream.manualsonline.com/0/0a0678fd-f9df-4e8f-8c98-0b4794c5453c.pdf
User-Manual
content.etilize.com/User-Manual/1031159306.pd
Oct 19, 2016 | Home
How to set the atomic clock
http://www.lacrossetechnology.com/products/resources/misc/8005-manual.pdf
Mar 16, 2015 | La Crosse Technology Black Model Wt-8005...
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
How to set an atomic alarm clock
Hello
I've the proceedings to setup the atomic clock, but this window does not allow me to send it by copying and paste the document, as it is out of this window's capacity. If you send your email address to me by Fixya comment box, I'll send a copy of it to you by return mail. OK.
Oct 23, 2011 | La Crosse Radio Controlled Atomic Clock
I have a lacrosse technology wall clock how do i set the time
You don't set the time. You set the Time Zone and it sets itself.
What model is YOUR clock?
This site lists several models of La Crosse wall clocks with downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
The link below is generic but there are specifc downloads for clocks with other features.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
La Crosse Radio Controlled Atomic Clock Logo
686 people viewed this question
Top La Crosse Home Experts
Are you a La Crosse Home Expert? Answer questions, earn points and help others
