Question about HP LaserJet 4100n Printer
Paper printing with wrinkles on hp 4100 laser
When printing several pages the last few come out with wrinkled line
in middle and bottom of page.
Posted by thewrightage on
  • thewrightage Mar 28, 2009
    just replace the fuser unit did not notice this problem
    before
    I had purchased a refurbished fuser.
    How can I tell if pressure roller nneds replaced
    Thank you
Anonymous
Pressure roller is worn. But the whole fuser assembly could probably stand to be replaced.
Posted on Mar 28, 2009
  • Anonymous Mar 28, 2009
    You replaced it? or had it replaced? maybe pressure roller wasn't replaced by whoever rebuilt it??
    Have a look at the pressure roller. Is it Wrinkled?
    you should be able to see it by opening the back cover of the machine, look at the fuser, and see if you can see the lower (orange) roller. If it's wrinkled / creased, it was not replaced, and is the cause of your trouble.
    Contact whoever you got this from from and get a "truly" refurbished unit.
The printed page comes out creased from the top left of the page to the bottom right.
Download this manual >> http://www.mediafire.com/?i0y9iqnqu79ppcj Go to page #203(6-15) Paper Feeding problems (wrinkles or creases) and follow the troubleshooting steps.
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing. http://get.adobe.com/reader/
Sep 03, 2011 | Brother HL 5140 Laser Printer
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
Paper wrinkles on left side when printing
Fuser is worn out (specifically, the pressure roller).
May 19, 2009 | HP LaserJet 1300 Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
HP LaserJet 4100n Printer Logo
258 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
