Is it hd
We have a 42'' plasma tv by Thomson Wysius and want to have Sky installed, by do not know if the tv is HD ready or not, we have read the manual and it does not mention anything about it, can you help?
Posted by joherbert on
  • joherbert Apr 05, 2009
    Thanks for your response, we have opted for Sky+without HD, but for future reference, that is a great help, thanks again
    Regards
Anonymous
  • 92 Answers
Strictly speaking to be HD Ready a TV must fullfill 2 things:
1. Have a Screen Resolution of at least 1024 x 768.
2. Have at least 1 HDMI Socket.
Your TV has neither of these, so it is NOT HD Ready, however, it will still be more than capable of showing SKY HD, and it will still look very nice indeed.
I would need a list of the connections on the rear of the TV to tell you which cable to buy, but:
If it has DVI, then a simple HDMI to DVI cable will do for the video.
If it has component, i.e Yb, Yr etc then you will need a more expensive HDMI - Component Video cable.
But otherwise, yes, SKY HD will work fine.
I hope this helps.
Posted on Mar 28, 2009
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
THE FOCUS IS WRONG. i CANT READ ALL THE SCREEN ON SKY SPORTS NEWS.
Plasma screens don't have a focus as such so I suspect a problem with the upscaling of your pictures.
Try a different resolution value or screen aspect size.
Hope that helps.
Nov 28, 2010 | LG 42PG60 42 in. HD-Ready Plasma TV
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Digital TV
It is HD ready, which means to get HD you will need to connect a HDMI cable to a HDMI source such as a SKY HD / VIRGIN HD SET TOP BOX or a HD DVD player to take advantage of HD.
Jan 22, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
HD4208TIII-PDP 42'' Plasma TV
Your TV may not support your HD channel signal. Check with HD DVD & non-HD DVD players to confirm.
Jan 01, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
HD READY
Im thinking this set will need an hd adaptor as you need at least 1081i resolution for hdtv.
Apr 04, 2006 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
