SOURCE: I have a 1994 Toyota Camry LE. The AC blows hot
Bad compressor, bad AC Clutch assembly or disconnected wires or a blown fuse.
SOURCE: 1995 toyota camry. loses rpm and dies while idling
Bad fuel pump or clogged filter. Limited info so I can't do much more. Check the catlytic converter,make sure it's clear.
SOURCE: where is the flasher on a 1994 toyota previa
The flasher is bolted to the firewall behind the right side of the instrument panel and you can't get to it from underneath the instrument panel. You will have to remove the center console fascia to get to the instrument cover screws and remove the instrument cover. Then you can get to the instrument holding screws and move the instrument panel out of the way. Either a service manual or AutoZone.com will have this information and pictures. Replace the flasher with a genuine Toyota flasher relay. The aftermarket relays might look like they fit but I have found out they don't work properly. The flasher is bolted to the firewall with a 13mm bolt. Take out the bolt and replace the flasher.
SOURCE: how can i remove an airlock in a toyota previa
how do i remove a heater matrix in a toyota previa plz
SOURCE: 1994 toyota previa idles rough and cuts off only
Change fuel filter, air filter and if that doesnt help check fuel pump pressure.
