Question about KitchenAid Dishwashers
Cloudy glasses my kitchaid dishwasher is making my glasses cloudy and other dishes are not rinsed well.
Posted by woodruff15 on
Mike
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. there is new product at www.dishwasherfilter.com that is guaranteed to solve this. it filters the water going into your dishwasher reducing the hard minerals and leaving your dishes spot free everytime. you will be amazed. it is very affordable. www.dishwasherfilter.com
Posted on May 10, 2009
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
Dishes are often dirty and glasses are cloudy even though they are rinsed before they go into the dishwasher
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 02, 2011 | Whirlpool Dishwashers
My glassware is coming out cloudy! the dishes are clean but the glasses and some of the stainless steel has a cloudy film Please Help! I am currentyl using a rinse aid and cascade powder detergent It...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Dec 15, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Suddenly my asko dishwasher is not cleaning my dishes effectivelyl-- there are cloudy smears all over my glass ware & cutlery-- I use a rinsing agent, but it makes it all worse.
soak the cloudy glass ware in white vinegar for at least 5 minutes. If you can remove it, it could be hard water. You need to adjust your detergent amount. Have you changed detergents ? If so use a high quality brand.
If vinegar doesn't remove the smears, it is probably etching that is caused by hard water, too hot water or prerinsing
Sep 17, 2010 | Asko Dishwashers
Cloudy dishes
Use an rinsing agent to assist with the removal of water deposits.
Jul 28, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Whirlpool Dishwasher---All Dishes Finish With Cloudy Film
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 12, 2010 | Whirlpool 24 in. DU930PWP Built-in...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Clear glass dishes are cloudy. What is causing it? We have checked the arms--they seem to be working fine. Some days it does better than others--today they were extremely cloudy. I washed the glasses by...
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is due to hard water deposits; make sure the salt reservoir is topped up. Do not worry about over-filling it.
If the cloudiness is not removed, it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. Dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Dec 17, 2009 | Dishwashers
My dishwasher is now leaving my dishes cloudy. What causes this?
Make sure that the rinse-aid(jet dry) container is full. If it is full have you noticed if it's level has not dropped. It is possible that the rinse-aid dispenser is plugged. This will cause the dishes to be cloudy. You can also try running the dishwaher empty and add a cup of vinegar to the bottom before your start. There is also this stuff called "dishwasher magic" that you can try running in the dishwasher to clean it. Try using a soap with the rinse-aid in it or install a basket with a rinse-aid tablet and see if that helps clear up those cloudy dishes.
Nov 08, 2009 | Frigidaire Dishwashers
Cloudy glassware, stained flatware
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 19, 2009 | Maytag 24 in. DWB1000 Built-in Dishwasher
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
