Question about Tomtom GO 520 GPS Receiver
Screen says no map found
We bought a refurbished 520 go , 2 days ago, it was great,
(ps no SD card instaled)
i connected to tom tom home, it said download updated map free, we done that,
now it says
NO MAPS FOUND
Help please
Posted by philgibbs on
Anonymous
  • 515 Answers
A while ago I put a larger sd card in to my unit,as i wanted to install the complete maps of the U.S.A, i PUT A uLTRA 2 GIG CARD IN, IT WORKED FINE, PUT MY GPS AWAY FOR A FEW MONTHS, YESTERDAy i put the...
Most likely you got a hot copy of the maps and it worked fine for a few minutes in the new unit. Check the course of the map because they know if they are purchased new or are being copied. Not saying you did anything wrong just saying the SD card can only be used for one unit. Contact the company and they will set you straight.
Apr 30, 2010 | Tomtom GO GPS Receiver
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
When i turn on the tom tom one
I saved the map on to my computer from the tom tom in Tom Tom Home and installed it on to a new SD card and now it working perfectly. I bought a 2mb SD card for £6.70 put it into a card reader and connected to computer and installed map and it gave me the instructions to put into device (Tom Tom) and switch on to connect then off and back into card reader to finish. Then I disconnected device which is important to do by the way put the new Sd card into Tom Tom and it is workink perfectly. I hope this help others who have problems.
May 17, 2009 | Tomtom One Europe v2 GPS Receiver
The map cartridge fell out of the bottom of the Tom Tom.
Yes, it can be replaced, the map cartridge is a standard SD memory card.
These can be bought quite cheap in most camera/computer stores or in several department stores.
They can also be bought online from amazon See Here $6.65
Once you have the new card, connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Apr 05, 2009 | Tomtom One XL GPS Receiver
Updated maps now tomtom710 will not store data
blet, nafik, just push that small & stupid switch on the upper left, to top, on SD card. It will mean that you switched off "write protected" mode on you SD card ;)
Or, make sure you have SanDisk make SD card ;)
Mar 01, 2009 | Tomtom ONE GPS Receiver
Tom tom Western european map
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
Feb 24, 2009 | Tomtom One XL GPS Receiver
Tom tom 520
if tomtom home says that you have maps installed, but its not seeing them, try re-installing the main application - its solved the problem for me on my 520.
Nov 03, 2008 | Tomtom GO 510 GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
No maps found??
my tom tom 510 would start, i have charge the tomtom with green light on, but tomtom is not coming up
Feb 09, 2008 | Tomtom GO 510 GPS Receiver
Tomtom GO 520 GPS Receiver Logo
446 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
