Question about Apple iPod nano 3rd Generation
My computer & itunes will not recognised ipod
Plug in my ipodnano 8GB to computer it starts to charge but isn't recognised in my computer or itunes. Has been working, connecting O.K up until now. Had it 6 months. I have tried all the 5R, reinstalled itunes with the update and nothing happening
Please help, very frustrated
Problem solved, I purchased a new USB cable and wahla it worked
Posted on Apr 06, 2009
Itunes not recognising ny ipod
Look inside the slot that you plug in your iPod, is there an orange piece of paper? If there isn't, then your iPod might have been damaged from something (such as water getting inside) which may prevent it from being recognized by your USB slot. Every Apple product does this and it voids the warranty I believe.
If there is an orange piece of paper visible, try going into "my computer" to be sure it's being recognized by your computer as a whole. If it says "_____'s iPod" then it can recognize it and it is iTunes that is causing the problems. Try a reinstallation and replugging your iPod in and out a few times.
Dec 27, 2010 | Apple iPod Nano Video 8GB Purple (5th Gen)...
Got a new Iphone 3Gs and all seems to be ok but when I connect it to my pc all I get is a "iTunes cannot connect to this iPhone because of an unknown error". I'm hoping its something simple that I've just...
If your using a MAC try the below steps as this worked for me:
1. User - Library - Prefrences - com.apple.iTunes.plist
2. Delete that com.apple.iTunes.plist
3. Restart the computer. It should recognise.
If your using a PC the steps are lengthy, and the steps are:
Restore I-Phone
1) Close all programs and restart computer.
2) Open iTunes and plug in powered off iPhone with direct USB connection.
3) If iTunes fails to connect to iPhone...continue to #4, if it does...restore.
4) Shut DOWN iTunes again.
5) Power OFF the iPhone & Disconnect from computer. (Power off two ways-one will work, hold home and sleep button until off or just hold sleep button until off)
6) Hold down Home button & connect to computer using direct connected USB cable (keep holding down the home button until iTunes sees it).
7) It should go into recovery mode and iTunes should recognise it.
8) If you want to recover to previous software version, Hold Alt/Shift and click restore in iTunes. Then select the old update version.
If the above steps doesnot work then try the below steps:
1. Turn the iPhone ON
2. CONNECT it to the computer with a DIRECT USB connection.
3. Make sure iTunes is open so you'll know when it enters DFU mode.
4. HOLD the Power/Sleep-Wake button AND the Home button for 10 seconds.
5. RELEASE only the Power/Sleep-Wake button and continue to hold the Home button.
6. WAIT until iTunes recognizes the phone in DFU Restore mode (in Windows a bubble pops up saying it recognized new hardware "DFU Mode" or something to that effect)
The last step may take SOME TIME, like, say, even 60 seconds or so.
The screen should be OFF (black), if you see the "Connect to iTunes" logo, START OVER.
It may take a few tries to do the steps just right, just reboot
(hold both Power/Sleep-Wake AND Home until the Apple logo appears and the phone turns back on) then try again.
7. Then restore the iphone
-Plug one end of the cord into your phone and the other in your computer
-Remove the cord in your computer, leaving the cord in the phone still plugged in
-Hold both the home button and on/off button on the phone
-Once the screen turns off, let go of the on/off button but continue holding the home button
-Plug in the other end of the cord in your computer while still holding the home button on the phone
-Once the apple logo appears, continue holding until you see the plug into itunes screen on your phone
-Click restore.
Hope this should resolve your issue :)
Mar 01, 2010 | Apple iPhone Smartphone
Fprgot password to my Ipod 8gb.
Click "Start"
Click "My computer"
Switch to the classic view (if you're using Windows XP.)
Click "Folder Options"
Click the tab called "View"
Check "Show hidden files or folders"
If you also wish to view system files, Uncheck "Hide protected operating system files"
Plug in your iPod.
Wait for it to load completely.
Open My Computer (or computer if on Vista). Make sure you can view hidden files.
Go to iPod_control.
Go to the folder named Device.
If your iPod is locked, there will be a file _locked . Rename the file to _unlocked.
Safely remove your iPod and it will be cleared.
If you need more help, let me know !!
Sep 10, 2009 | Apple iPod touch
My ipone (8gb) constansly says to connect to itunes
Hold down the "Sleep/Wake" button while holding down the "Home" button. once your iPhone starts to reset let go of the "Sleep/Wake" button but keep holding down the "Home" button until your computer recognizes your iPhone.
Aug 29, 2009 | Apple iPod touch
My Computer and iTunes does not recognize my iPod
Try connecting this ipod to rear USB port on your desktop computer and then try this out
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
It should work fine
Nov 26, 2008 | Apple iPod MA446LL/A MP3 Player
I pod touch
ipods are only designed for itunes so windows shouldn't recognise media player, any way, the new software for ipod touches is greater, meaning your computer/windows media player wont recognise it, only itunes will.
Cheers
Oct 18, 2008 | Apple iPod touch
Have you tried resetting it? Press the center (Select) button and the Menu button at the same time and hold for at least 10 seconds or until you see it reset.
hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Apple iPod nano
Try this: turn off your ipod, hold the home button, and plug it into itunes while still holding the home button until a picture of the itunes symbol appears with a cable under it. itunes should say "ipod found in restore mode". This will completely reset your ipod, hopefully fixing any bugs or problems in it. also, you will lose all data saved on the ipod that isn't also backed up by itunes. Music, pictures, and video can be re-synced.
Aug 16, 2008 | Apple iPod touch
Computer cant find ipod
1. ipod default setting is not set as a mass storage device.
2. you might have to restore ipod to manufactor default setting (from itunes). WARNING: all music will be erase.
Try to plug it in another computer/laptop
May 22, 2008 | Apple iPod nano
Nano Will Charge on Laptop/ Will Not Sync & Will Not Connect to Itunes
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Mar 19, 2008 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
80 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
