Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Kodak5500aio printer will not print
Attention light flashing. screen says replace colour ink cartridge. i only need black at this time.
Posted by noelnettle on
Andrew Perrong
    Sergeant:
  • Kodak Expert
  • 285 Answers
You will need to replace it. There is almost no way around it.
Posted on Apr 11, 2009
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: sharp AJ1800 printer - won't print colour
the color cartrige is defective. replace only with original cartriges
Posted on Mar 23, 2008
khanmohammad
Nadeem Uddin
  • 188 Answers
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Posted on Mar 25, 2008
Anonymous
  • 21 Answers
SOURCE: HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
Anonymous
  • 164 Answers
SOURCE: Ink light keeps flashing
reset the printer by turning it off, waiting 10 seconds and turning it back on, also right click on My Computer and select manage..go to services and stop and restart the spooler service
Posted on Jul 24, 2009
Anonymous
SOURCE: can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Posted on Aug 10, 2009
I replaced the color cartridge with a new one. The new cartridge was the wrong size. I placed the old colour cartridge back in the printer and now the printer will not work. The ink drop for the colour...
Hp is known for being a pain with ink.
We once had a business jet that would not print because our ink had expired lol...
The printer wont work because it know's that the old cart has no ink. And since it needs all three colors along with black to print it will not do it, Usually you can set the printer to print only black under properties or print settings.
Other then that you will need another cartridge. You can also try one more thing. If you need to print in a Pinch, down on the right hand part of your screen, Is the clock. Double click it and change the date back a year from today and see if that helps you print
Oct 06, 2010 | HP Deskjet 6980 InkJet Photo Printer
Printing with my Kodak easyshare 5300
it is necessary to install the colour cartridge.to use with black
Aug 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Orange cartridge light is flashing. I know the black cartridge is empty, but the colour cartridge is o.k. Why can't I print in colour?
Inkjet printers use a combination of inks to produce colors; while you may not realize it, your printer uses black ink to print colors as well, to darken the hue of a color. Otherwise, it would be limited to very "bright" colors. Replace the black cartridge, you will be fine.
Mar 05, 2010 | HP PSC 1350 All-In-One Thermal Printer
My printer screen says
The ink is contained in a cartridge.
Note that "backup" printing mode mixes colours, to produce "black", because the "black" ink-cartridge has failed.
So, replace the BLACK ink-cartridge.
Jan 05, 2010 | HP Photosmart 8150 InkJet Printer
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Apr 09, 2008 | Lexmark X1240 All-In-One InkJet Printer
Low black ink - can not print at all
Most epson inkjets that use separate colour and black cartridges will not print if either the colour or the black cartridge is empty. The printers come with cartridges when new but they are only part full and more ink is used up filling the printer reservoir when first starting up. Replace your black cartridge and you should be able to print. barrie60s
Jul 24, 2006 | Epson Stylus C88 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
42 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
