Hi, my mouse work fine since pressed simultaneously the buttons of the mouse and the receiver. Previously, I had disarm the receiver, but all was fine, so I'd arm again the receiver and plug to laptop; I'd press both buttons and mouse work. For any reasson, mouse and receiver lost conection and is necessary re-establish comunication pressed both buttons. I hope my experience (my case) to be useful to someone.
hehehe i wondered the same thing when i got my wireless mouse, it has a auto shutoff feature, if its not moved, it will turn off, i reconmend putting a piece of black tape on the sensor on the bottom to keep it from turning on when its being moved
I have the same mouse. Make sure batteries are good. Then plug in the usb receiver. On the receiver, press the green led light, then press the connect button on the underside of the mouse. they should connect.
Try resetting the mouse. On the base of
the mouse, there is a red reset button. Press that, while
simultaneously pressing the black reset button on the base of the
charger. The laser light should becomes steady after a moment,
indicating that the mouse is in sync with the laptop. If the laser is
blinking, however, then the mouse is attempting to become synced. You
may have to press the reset button multiple times. Hope this helps.
Yeah, I was kind of confused about this too. Apparently, on the base of the mouse, there is a red reset button. Press that, while simultaneously pressing the black reset button on the base of the charger. The laser light should becomes steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
You don't need a driver for this mouse. I've tried downloading some. Just try syncing it with the laptop. On the base of
There is a light/button on the USB plug. After inserting the USB key press that button then immediately press the connect button on the bottom of your mouse.
the mouse, there is a red reset button. Press it, while
simultaneously pressing the black reset button on the base of the USB-connected charger. The laser light should become steady after a moment,
what model is it?
