My microwave says S or 5E on the display and will not let you push an buttons or anything. The light works and the turntable goes by itself when the door is not properly closed. I have tried leaving it unplugged (for days) and it does the same thing s soon as it I plugged back in. 8888 followed by a couple of beeps then the SE comes on.
SOURCE: kenmore microwave model number 401.80084700 Displaying -SE-/-5E-
-SE- error means you
have a shorted membrane keypad.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There are three ways you can get it fixed:
DE34-00178X SWITCH MEMBRANE $20.30
ref#53 membrane keypad
take yours off as in the video at
our site, peel the old keypad off as in this
handy guide with pictures
, clean the surface, stick on the new keypad
order by part number here
(We can do this job for you for a total of $70.25, but as you can see, the other two options are more practical and economical)
DE94-01647A ASY CONTROL PANEL $39.01
ref#66 control panel frame with keypad
our site, disconnect the keypad strip as shown
here, move your circuit board to the new frame, reinstall
DE94-01648A ASY CONTROL, BOX $58.12
ref#59 complete control panel assembly with frame, keypad and circuit board
our site, then install the new one
If these parts are not in stock, they should be available in about a week or so.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: Maytag microwave that has a code of 5E or SE. The
I have the same problem. Did you get an answer? Thanks. l issa
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
