Question about Kodak EASYSHARE 5100 All-In-One Printer
Will not print in black
Will print in color but not black. Black cartridge is not empty
Posted by gcox552 on
Anonymous
  • 3 Answers
This seems to be a common problem on the 5100
Contact Kodak Support who will ask you to re-insert cartridge, Print Clean, Calibrate and run print test (press Photo & Copy together) then tell you that you need a new Print Cradle! Which they will supply FREE of Charge by overnight carrier.
Posted on Mar 29, 2009
Only one black cartridge on my canon mp560 is empty, but all the colored ones and smaller black one are full, but my printer will not print
Once a cartridge is empty the printer will not print untill a new cartridge is put in, just replace the empty black cartridge
Jul 21, 2014 | Canon MP560 All-In-One InkJet Printer
WITH THE LEXMARK X2250 ALL-IN-ONE PRINTER CAN I USE THE COLOR INK CARTRIDGE TO PRINT BLACK, IF MY BLACK CARTRIDGE IS EMPTY? HOW CAN I DO THIS?
when your black cartridge goes empty , the printer automatically goes into the reserve mode where it mix up the colors in the color cartridge to produce black color
Aug 06, 2012 | Lexmark X2250 All-In-One InkJet Printer
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I have a lexmark z2320 inkjet printer the colour cartridge is empty should it still print the black is full
I'm not a computer geek at all, but I find the color cartridges always run out first. Try to change your printer settings so it will only print in black and white and so uses the black cartridge and not the color one. If the the color cartridge is empty, the page will not print correctly. It may print some of the black color only.
Mar 26, 2011 | Lexmark Z2320 InkJet Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
The color cartridge runs out very quickly even though I rarely use it. I make sure to print in black and white, and I manually choose the option "Use Black Cartridge only" but the color cartridge runs out...
Printer manufacturers design their printers to print some color mixed in with the black when you are only printing black. That is why your color cartridge is running out when you only print black and why it prints "weird colors" when the color cartridge is empty. Printer manufacturers sell the printers at a loss and make up the profit on the cartridges.
Feb 20, 2009 | HP D4360 DeskJet Printer InkJet
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Pixma MP610 - fab machine - only problem is that the large of the black cartridges empties - never uses the smaller one (No 5) why? It refuses to print if the No 8 is empty. What do I need to do please?
The large of the black cartridge (5) is for ordinary paper in printing menu of computer. Selecting photo paper uses only the small black cartridge (8) and the color cartridges are used to make black even for gray black printing. Choosing ordinary paper, you can print in black 10 even 20 times with the large black cartridge (5) (by refilling and quoted as empty) . You simply need to press a long time the hold button, as explained in the manual on the printer CD, to continue to print with an empty cartridge. (at least in Europe)
The color cartridges are slightly used even when printing only in black and become empty, even if you never use the colors!
Jul 28, 2008 | Office Equipment & Supplies
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
82 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
