NONE OF THE BUTTONS ON TV WORK BUT I HAVE PICTURE
SOURCE: Can't see the top or bottom of screen on my emerson 32" Flat Scre
If it's like mine, there should be a screen mode button on your remote. Keep pressing it to change to different settings.
SOURCE: Emerson MP3 Player Won't Function
i have the same problem with mine. i just bought it. what i do is just simply hit the "reset" button at the back, and it starts working again. also, if u actually sync songs onto the mp3, it doesnt give that error message for some reason.... the problem i'm having with mine though is that it isnt fully charging no matter how long i leave it plugged in
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
SOURCE: I have a new Emerson LC320EMX 32
Similar to mine, only my tv you can change channels. We either need someones help or atleast a service manual (not user manual)
Your TV is still in the factory test mode. To remove from the tech service mode try this.To exit the service mode, grab the original remote. Press the cursor left followed by the cursor right button. Now press the off button on the remote or on the TV itself. Hope this helps. Thanks for asking and show a few hands of support!
The Child Lock feature prevents unauthorized viewing of the
television. To activate, press and hold the Function key, and then
press MUTE. you should see a key symbol appear on the screen.
This will lock out all remote functions (except for Standby). To unlock
the TV, press and hold the Function key and press MUTE. This will
unlock the TV. Please note that the only way to activate or deactivate
the Child lock feature is via remote control - please insure that it is
stored securely.
