Car Audio & Video Logo
Posted on Mar 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hissing/static when I plug the unit in, I get a hissing/static sound & when I apply the brakes, I get a high pitched noise.
Anonymous
Level 2:
  • Expert 108 Answers
  • Posted on Mar 28, 2009
Anonymous
Expert
Level 2:
Answers
108
Questions
0
Helped
45395
Points
310
Check all ground wires for radio and xm and make sure xm antenna is mounted on metal surface
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
High pitch droning sound
There is a metal tab on some pads that contacts the rotor to make hideous noises telling the driver they need to replace the brake pads. It's in your owner's manual.
Hissing noise when braking
The hiss sounds like the power brake booster has failed.....but usually that only causes the pedal to get hard. A pedal that goes all the way to the floor normally indicates a bad brake master cylinder.
Squeaking and grinding noise when I apply the brakes
Try replacing or resurfacing your rotors and brake hardware. Using brake pads similar to the oem will also help stop any problems.
Hissing noise under dash of Cummings diesel
Hi Shelly, Your explanation is a little short on detail. I suggest that you take a length of plastic tubing and while the engine is running, and the hissing sound is evident, place one side of the tube to your ear move the other end to the different units fitted under the dash until the noise is loudest. Once you've done that you can identify where the defective joint or unit is. Regards John
2001 ford escape makes a hissing and high pitched squealing sound when the brake pedal is released?
You need to have the brakes inspected. This noise is the brake pad wear warning tab hitting the brake rotor.;
2answers
Hissing sound from under the driver's side of
Yes sound like brake booster. most of time when booster is going bad makes hissing sound when brake applied.But should not make any kind of air leakage noise at all.Replace brake booster.Hope this was helpful for you.
1helpful
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
John
John
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
