Question about Samsung ML 2010 Laser Printer
Overheat fuser ml 2010 samsung i feeling a technically not 180c & 356f
Samsung ML 2010 Laser Printer over heat temrature driving what is solution & repairing DC conrolling board
Posted by dumbre goraksha on
3 Related Answers
SamsuTech
  • 113 Answers
SOURCE: where is the fuse on the samsung ml-2010 laser
which fuse at you looking for. if you are looking for the fuser that will be the item behind the printer. open up the back door you will be able to see the fuser.
if you are looking for the electric fuse. that will be on the main boad. it is right behind too. open up the back cover you will be able to locate the fuse.
Posted on May 21, 2010
ikkenom
  • 10406 Answers
SOURCE: Solutions for "engine fuser low
The "fuser" should heat-up to its operating temperature to "melt" the dry toner-ink onto the paper.
If it is not heating up, then each page you print and brush with your fingers will remove the toner.
So, replace the fuser, or get it professionally replaced.
Posted on May 15, 2011
guilopmar
  • 304 Answers
SOURCE: I am now using a Samsung ML 2010 Laser Printer but
Yes, is the same cartidge.
Posted on Jun 27, 2011
May 15, 2011 | Samsung ML-3561N Laser Printer
Problem for Samsung ML-2855ND Laser Printer Led screen says open heat error cycle power, how do i fix this?
to totaly resovled this issue you got to replace the fuser & (SMPS) power board on the printer.
if not every time you on the printer you got to off it for 5mins and restart the printer again.
May 21, 2010 | Samsung ML-2855ND Laser Printer
Where is the fuse on the samsung ml-2010 laser
May 20, 2010 | Samsung ML 2010 Laser Printer
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
Samsung ml 2010
i want driver of ml2010
Jun 16, 2008 | Samsung ML 2010 Laser Printer
Fuser Error
you must change the fuser.
Sergio
Mar 03, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
29 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
